29-03-15, 09:48 AM
checked the clutch plates? the basket could be worn
Had my cam chain done but...
29-03-15, 09:48 AM
29-03-15, 09:49 AM
Had the clutch apart earlier in this thread but don't really know what I'm looking for.
There's a noise that stops when I pull the clutch lever as normal but this tapping is different and remains constant?
29-03-15, 11:47 AM
ahh ok...
Maybe take "feeder" up on the offer of looking at it
31-03-15, 09:12 AM
difficult from video but sounds vey much like exhaust blow from falnges ?
easy to check and relatively easy to fix
waters wet, shit stinks !
31-03-15, 01:54 PM
He did remove cams mind you so should be timed
as said when I move the pump it stops though. Also think I do have a slight downpipe blow but that's a different noise lol Deefer thinks he knows what it could be my issue is distance
31-03-15, 04:43 PM
a slight blow on headres can sound like a loud ticking !
if it starts ok runs ok then : as i said diffficult to tell on video but does sound very suspect i`d sort the exhaust blow out and see if the noise goes !! :eek :eek
31-03-15, 04:58 PM
Are these just gaskets, is there a guide?
Well do that but as said when I move the water pump it goes so Im pretty sure it isn't that. It's blowing on my link pipe too but can't seem to find a decent way to seal that either ![]() Cheers
01-04-15, 01:58 PM
i`d have a look for you matey but i`m further away than deefer666
i`m up in yorkshire :lol :lol
01-04-15, 02:12 PM
07-04-15, 08:05 AM
you got this sorted yet mate ? if so be interesting to know what it was
07-04-15, 08:06 AM
Funny actually.
I sooner had I clicked send on a pm to Deefer, you clicked post on this. Looking into it now. Steering rack went on the car the other day so that was priority
19-04-15, 07:44 PM
Deefer didn't reply
![]() Seems the oil pump is the next culprit. Problem is, I'm not sure how involved changing it will be. any suggestions, is it worth the effort and is it a mental job? Will it involve splitting the chain or just removing the tensioner etc? Second hand worth it?
30-04-15, 05:07 PM
Changed the oil pump.
Still does it. Now what!? ![]() Deefer?
30-04-15, 05:25 PM
how odd :S
30-04-15, 05:44 PM
Same again loosen water pump and the noise goes
30-04-15, 08:37 PM
Maybe sounds a bit daft but!! Have you checked how much you need to tighten the water pump up? I have had a time when the pump would not sit flush due to shaft pump interface. What it was that the pump required a lot of preasure to screw down. when I took a bit off the shaft,about 0.020" I could push the pump tight on without the screws so only needed a nip up to get it seated. Just a thought? try 2 gaskets see if the noise goes.
30-04-15, 08:41 PM
There's no gasket on that face though that's the annoying thing.
Does seem like that though was tempted to put a thin washer between the pump face and crank case if that makes sense just to push the pump put a touch. The rubber o ring will still be there so the oil shouldn't leak either. Seems odd that this could suddenly happen but I can't loosen the bolts and ride it to test as it leaks coolant. But you saying to use 2 gaskets makes sense, shame there aren't any so I may try the washer thing? Cheers
04-05-15, 06:02 PM
I've found the problem if anyone is following this still...
04-05-15, 06:58 PM
It's always good to hear about a problem solved
« Next Oldest | Next Newest »
