chain cleaning
#41
My chain looked similar so had a go at it with a mate of mine last week. We used gunk degreaser, then wd40 and a wire brush on the outside of the links to shift the surface rust. Took about hour and a half! More degreaser and a good rinse off followed by a whole can of castrol race chain lube. Looks ace and I actually think I could feel the difference riding home.
Nothing Fazes a Foccer!
I was thinking about using a brass wire brush.  Is this frowned upon ? Steel brush ? Or stick to a tooth brush so the chain isn't scratched ?
I certainly wasn't going to be the first to put my head over the parapet and get stoned for mentioning a wire brush.
I think it's not a good idea as it can trash the joints between the links. On the flat faces to remove rust if you were careful it might be ok but probably best to stick with the toothbrush and elbow grease  Wink  WD40 to clean it and plenty of chain lube after  8)
Chris
[Image: 208008.png]
Toothbrush. Oil or paraffin. 1st gear.
Trust me, I'm a lawman
Smell ones mother. Yaas!
(18-05-13, 06:19 PM)Raymy link Wrote: Toothbrush. Oil or paraffin. 1st gear.
With no fingers Smile)Smile)Smile)
[Image: 850481.png]
Yeah Def only on the face of the links with a wire brush! Degreaser and toothbrush should be enough for the rest
another good way of cleaning a chain--a good stiff rub down wi a hedgehog that'll do the trick.
(19-05-13, 04:47 PM)Oldgit link Wrote: another good way of cleaning a chain--a good stiff rub down wi a hedgehog that'll do the trick.
Is that a cooperative or uncooperative hedgehog ?
