10-06-22, 08:17 PM
After not using my Fazer much last year due to injury, I had engine running problems which I attributed to a gummed up carb. Cleaning spray and redex would help a bit but not for long.
So I bit the bullet and removed the carbs to clean... I recorded how many turns out the pilot screws were (about 2.25-2.5) and put all the jets and needles etc in the ultrasonic cleaner with some cleaning fluid diluted with distilled water. All good, except I spilled some coolant on one of the spark plugs when removing the carb, which seemed to cause that plug to not spark. Replacement spark plugs and NGK connectors were fitted. Leads trimmed a bit to get fresh conductor. Everything went back together OK.
Next, I did the balancing using some vacuum gauges. This was a nightmare and took quite a while. It seemed I could get it pretty much on-point but then a few minutes later it'd be way off again. I iterated around and managed to get to something that was roughly consistent.
But... it sounds "wrong" like it's running on 3 cylinders when idling. Exhaust from cylinder #1 measures about 30 degrees cooler than the other three cylinders. Have tweaked the pilot screw back and forth on #1 +/- 1 turn and it hasn't made a difference.
I had an MOT this week and the guy said it sounds like the Pilot is really badly adjusted, or its a dodgy coil pack. I ordered a couple of coil packs to try - should be here next week.
When riding on throttle it sounds better and feels like it has full power (not like it did when running on 3 with the wet plug).
Beginning to get to the end of my tether on this - If the coil packs don't fix it, I have to send it for a proper carb setup at the workshop... before I do, does anyone have any words of wisdom?
Andy
2003 FZS600 - Owned from new.
Andy
