30-07-18, 09:25 PM
I may struggle with my extremely limited knowledge with electrics, to fit this as it isn’t the same pins to plug in..any tips?
LED Flashers
30-07-18, 09:25 PM
30-07-18, 10:07 PM
Oh yeah. I made up 2 wires - one end fitted with a male spade end connector and the other end with a female spade end connector. Both wires the same to make an 'extension cable'. Only needs to be a few inches long. Doesn't matter which way around you connect to the relay.
30-07-18, 10:20 PM
Cheers pal, I’ll give i a try
02-08-18, 10:54 PM
Adjustable flasher relay arrived and I doctored up some leads to fit..seems to work so far..flash rate is constant up to 4K revs while bike in neutral so i cant see why that would change once on the road..fingers crossed! Thanks for the tips all
Az
03-08-18, 06:03 AM
Great. Will keep fingers crossed...
05-08-18, 03:51 PM
All good! Thanks mate!
« Next Oldest | Next Newest »
