Front sprocket change
#21
I think of it as a swing arm protector. Without it the chain would wear away the top/bottom surface of swing arm-its just Japanese not having exactly right word for it!
(04-06-17, 11:06 AM)Dave48 link Wrote: I think of it as a swing arm protector. Without it the chain would wear away the top/bottom surface of swing arm-its just Japanese not having exactly right word for it!
"Rubbery"  :lol
I dont know of anyone on here who has had to replace a completely worn one, your chain would have to be so slack as to wear through it that you would have other problems, like it jumping off
(02-06-17, 01:16 PM)darrsi link Wrote: If you've adjusted the chain by moving the rear wheel you may have slightly put it in a different position.
So the noise "could" be the chain cutting a new path on the plastic chain guide?
Tends to sound worse when people upgrade to new heavier duty chains, it makes a buzzing/rubbing noise.
If its cutting a new path, its too tight.
(08-06-17, 10:33 AM)BBROWN1664 link Wrote: [quote author=darrsi link=topic=22688.msg261842#msg261842 date=1496405808]
Or a heavier than standard replacement chain, they need a bit of bedding in when first fitting, which is what causes the loud noise. Had it myself, and others on here have had it as well before, it's nothing new.
