Front sprocket change
HI All  Big Grin
Recently had some noise coming from the chain/ front sprocket on my Fazer FZS600 2002. Removed the cover and looks like that sprocket needs to be replaced as some of it cracked (see pic attached). I want to buy sprocket, retainer and retainer nut online  but from the pics online shops looks like that sprocket got a different look. I am using that shop:  http://www.wemoto.com/bikes/yamaha/fzs_6..._sp/02-03/
They have different types of sprockets and I am not sure which one is correct. They have less or added teeth
[size=78%]Can anyone help? [/size] :'(
Thanks
Dawid
Zielik
You can't can't just replace the front sprocket, with that much wear you'll need to change the chain and rear sprocket too.
This front sprocket
http://www.wemoto.com/bikes/yamaha/fzs_6...ront_-_jt/
This year sprocket
And this chain
Retainer and nut
(\__/) This is bunny. Copy and paste
(x'.'x) bunny onto your page to help
(")-(") him gain world domination!
Chill out!!
The sprocket is fine, some fazer have the sprocket encased in plastic to try and reduce noise, all that has happen is that some of the plastic has cracked and fallen off.
Mine is a lot worse and still works fine.
Save your self the money and remove any loose bits and carry on.
Only needs replacing if the teeth are becoming hooked which isn't clear in your pic but looks ok.
Hard to say from your pic.
But if you do change the front sprocket and only the front sprocket, you need to be confident that there is little or no stretch in your chain, no tight spots etc.
That front sprocket is fine, it still has one tooth left :lol
(31-05-17, 07:46 PM)Skippernick link Wrote: Chill out!!
Problem is that mine started to be noisy when riding slowly and I think is because the missing places on the sprocket case. It's really loud (hard to explain the type of noise)  :\
[size=78%]It's getting worse when leaning which could indicate wrong chain tension but I've adjusted it but it didn't cancel the noise.[/size]
Zielik
(31-05-17, 07:37 PM)celticbiker link Wrote: You can't can't just replace the front sprocket, with that much wear you'll need to change the chain and rear sprocket too.
This front sprocket
This year sprocket
And this chain
Retainer and nut
Hi Celticbiker
Thank you for reply and all the links, but all links are for the same front sprocket :-(
I think that it is time anyway to replace all of the above.  :'(
Thanks
Dawid
Zielik
(31-05-17, 09:30 PM)zielik link Wrote: [quote author=celticbiker link=topic=22688.msg261742#msg261742 date=1496255851]
This front sprocket
This year sprocket
And this chain
Retainer and nut
Hi Celticbiker
Thank you for reply and all the links, but all are to the same link of the front sprocket.
Thanks
Dawid
Zielik
If you've adjusted the chain by moving the rear wheel you may have slightly put it in a different position.
So the noise "could" be the chain cutting a new path on the plastic chain guide?
Tends to sound worse when people upgrade to new heavier duty chains, it makes a buzzing/rubbing noise.
(02-06-17, 01:16 PM)darrsi link Wrote: If you've adjusted the chain by moving the rear wheel you may have slightly put it in a different position.
Sorry, but this post is the most ignorant, dimwitted piece of 'advice' I've ever seen on a forum. What the hell are you talking about?
'New path on the chain guide' my arse.
Evidence of this?
(02-06-17, 04:23 PM)Simon.Pieman link Wrote: [quote author=darrsi link=topic=22688.msg261842#msg261842 date=1496405808]
Evidence of this?
Oh, it's you again, you bellend.
If you can't figure it out just fuck off and do one.
(31-05-17, 06:35 PM)zielik link Wrote: HI All  Big Grin
Thanks
Dawid
Does all look rather clean and a bit too dry in the picture, how often do you oil or lube the chain?
(02-06-17, 06:53 PM)darrsi link Wrote: [quote author=Simon.Pieman link=topic=22688.msg261853#msg261853 date=1496417013]
Evidence of this?
I must say Pieman, do you get smacked a lot in real life, because if you talk to people like you post then I'm not surprised.
Don't consider  a diplomatic service job unless its for Trump then you would fit in perfectly.
(02-06-17, 06:53 PM)darrsi link Wrote: Oh, it's you again, you bellend.
:lol :lol :lol
didya check the sprocket lube before ya put de chain on coz the rear sprocket will make it noisy..ooops another bellend just replied. :'(
If I wanted to make a life-long career out of
working with the mentally retarded I would
have opened a Harley Davidson Dealership!
(02-06-17, 07:13 PM)Skippernick link Wrote: [quote author=darrsi link=topic=22688.msg261857#msg261857 date=1496426022]
Evidence of this?
Seriously, he must work in Customer Services for 'Cunts R Us'.
I encourage anyone to discuss, or even question my sometimes dubious theories, but there's a small matter of manners. We all learn new stuff every day, whether it be to do with fixing the bike or riding it, and we all get on extremely well on here, having a laugh but being educated along the way.
But if you go full on and take a random snipe at me, don't expect me to react too well.
That's twice now he's managed to rattle me by being a troll like wanker.
It's not welcome and i will not tolerate it, and i reckon he needs to go back to the Early Learning Centre to pick up some very needed simple social skills.
Evidence of this?
Its called a chain guide- I have no idea why its needed because its a piece of rubber that does not guide the chain - it just gets cut by the chain as it rubs past it, mine has.
(03-06-17, 11:41 PM)fazersharp link Wrote: [quote author=Simon.Pieman link=topic=22688.msg261853#msg261853 date=1496417013]
Evidence of this?
[/quote
It's just the name of the part.
And if you check it, you'll notice the chain wears a path, quite simple really.
If you upset the chain by moving the rear wheelby a fraction of a millimetre it will rub against the sides creating a new path, and a bit of noise again until bedded in.
Very common if you upgrade from an OEM to a D.I.D. for example.
Been there, done that, as have many others on here.  Smile [/quote]
(04-06-17, 12:05 AM)darrsi link Wrote: [quote author=fazersharp link=topic=22688.msg261956#msg261956 date=1496529703]
Evidence of this?
[/quote
Yep thats what I meant when I said  "it just gets cut by the chain as it rubs past it, mine has."
Yes I have a grove cut into it and can well imagine it would make a noise cutting a new path
Evidence of this?
Metal could create sparks towards the engine i s'pose, so not entirely ideal if you were to have a fuel leak, unless you dig that Ghost Rider look.  :lol
