Idling trouble
#21
I can't cancel my order now since it's through Yamaha directly and paid but might still have them for spares! You don't happen to have the tps sensor aswell?
Give me a welder and Ill run you a bead... Give me a bike and Ill ride it till it blows but I cant fix them....
Unfortunately not, I  sold it over a year ago to a fellow called Dan in Russia because he could not get one and had been looking for some time for one.
There are a few Suzuki and Kawasaki ones which will fit since they also use the same type Kehin carbs and are the TPS is also made by Kehin, but have shorter leads and you will need to make a few changes to the wiring to get it to fit. The lead on the 400 one is one of the longest I have come across on TPSs.
I have the info somewhere on my PC as to what one will fit, just need to find it.
If you want the carbs I can send them by courier and I will check the courier price and if I can get for less than what I think it will be, I will reduce the price accordingly.
The carbs have been stored dry, since they were taken off the bike just before I paid for the bike when I was buying it in Stoke on Trent. They were running, before they were removed, but I can open them and check everything is ok if necessary.
There was a problem starting it cold and when I pointed out the broken piece to the seller he replaced the carbs, but I kept the originals.  Smile
PM sent
PM sent back  :lol
Alternative TPS for the Fazer 400, these may have a shorter lead which will need extending.
There may be others but I found these after a short search.
This site throws up a few new and used
http://www.frankmxparts.com/Throttle-Pos...aha-WR400F (remove the plate and it is the same)
http://www.frankmxparts.com/Throttle-Pos...uretor-new
Picture shows 3 different model of bike including the Carburetor model R6 this looks a slightly different shape but the same fitting.
Occasionally like the Fazer 1000 replacement from a DR400 it works in reverse, but this is easily fixed by swapping 2 wires over.
