13-12-15, 04:00 PM
As far as downforce I don't think they will be particularly efficient, it is mainly cosmetic however we shall see
The finished part will extend behind the upper fairing and mount at the rear fairing bracket and the indicator hole, I will probably incorporate a mount point on the front upper radiator shroud mount point too just to keep in in place width wise.
The basic shape is pretty much where I want it before I put body filler on and finalise the shape/curves ready to make a mould off it. I am not 100% set on the lower section angle or the front upper radius at the mo. It also lookss a bit blunt on the leading edge but I am wondering about laying the carbon in such a tight angle, it should be fine, I guess I can refine the shape in future versions if I am not happy with it.
Side on - the front, where it meets the upper fairing will be flush, it looks a bit stepped forward here but its jsut because I have simply shoved it in place. The foam is a bit cut and shut as I used some offsets that were too small to use in a single piece, when I do the left I will use single blocks as its easier to shape without glue inbetween...
![[Image: 23426521730_4f0a23e02f_z.jpg]](https://farm1.staticflickr.com/641/23426521730_4f0a23e02f_z.jpg)
![[Image: 23095159953_4f195a54f5_z.jpg]](https://farm1.staticflickr.com/638/23095159953_4f195a54f5_z.jpg)
![[Image: 23639665421_63db8ec191_z.jpg]](https://farm1.staticflickr.com/593/23639665421_63db8ec191_z.jpg)
Anywho, just opened my filler tin and there isn't enough to cover this really so that's it for now...
Intentionally left blank
