Front Brake judder
#21
Yeah, that's why after they were powder coated I lightly sanded/filed them back to the bare metal on the hubs to make sure the surface was flat.
Chris
[Image: 208008.png]
(27-08-15, 11:06 PM)Chris link Wrote: Yeah, that's why after they were powder coated I lightly sanded/filed them back to the bare metal on the hubs to make sure the surface was flat.
Chris
I had my discs off so many times my hub surfaces were also spotlessly clean as well, i also bought new discs and managed to buy some very cheap used discs as well and kept rotating them on the bike in desperation to try and sort things out, as well as scrubbing the disc surfaces, and different types and makes of pads.
I have 98/99 forks on my 2000 bike, without the adjusters, which i personally thought were useless anyway, and i believe my wheel bearings were replaced too.
Oh, and the steering head bearings were changed too (not a fun job). You've not mentioned head bearings, i presume you've checked for any play?
When buying new discs it's very important to remove the protective film that's on the discs with brake cleaner until they are spotless, bit late now but thought i'd mention it anyway! You can try and burn it off by hard braking but can presumably contaminate the pads with it.
My calipers were serviced by me 2 or 3 times a year, that's why i got a bit good at doing it because it was so often.  Confusedmash
So, as you can see, a very similar, very frustrating scenerio.  :'(
[size=1em]I still think the brake lines could be the culprit, in one way or another, but that's me probably being a little biased.[/size]
Whilst i did all this myself, i also had 3 or 4 mechanics evaluate it too, and they couldn't figure out the problem either, it was 2 of my mates chatting who suggested changing the braided brake lines, but in fairness there was really nothing else left to suggest as it had already been done!  :think
so had a chance to try the bike with one caliper tied up out of the way and went for a little run and then tied the other side up out the way and went fro another little run.
Results are a little odd.. No pulse through the lever on either run but definitely a bit of rumbling from the front end enough to still shake the mirrors a bit. Wondering if this points more to front wheel bearings. I'm guessing that with both calipers on it's trying to pull the wheel either way causing the pulse through the lever as the brakes favour one side then the other. And with just one caliper on it isn't constantly trying to fight that force... It makes sense in my head anyway.
Now, I do remember when I had the wheels powder coated that the front bearings were, what I considered to be very tight going in. Because of this when it came to fitting the rear wheel I sanded out the bearing seat to remove any primer from the powder coating process. So, it could be that the front bearings have been too tight... There doesn't appear to be any play in them on rotation while up on the jack or side to side (checked by holding top and bottom of wheel and then rotating wheel 90 degrees and pushing again etc all the way around). Head stock bearing also appears fine, no notches and doesn't settle in any position when front wheel is off the ground.
Have ordered new bearings for the princely sum of £8 so worth a try. Will remove old bearings and clean out bearing seats to make sure they are to bare metal.
Chris
[Image: 208008.png]
I find the simplest way to check if head bearings are maybe loose is by having the bike on the ground, push it forward a bit then pull hard on the front brake lever.
If they are not tightened up enough then you will hear and feel a knock.
Obviously if they were not torqued as they should be then braking force would cause a juddering sensation because of the play.
A bit like when you get a loose wheel on a shopping trolley!
Ok, will try that too. Thanks
Chris
[Image: 208008.png]
So today,
Checked headstock bearings and seem to be ok but will change them if I can't solve it by doing other easier/cheaper things first.
New front wheel bearings arrived today so displaced front calipers and spun the wheel, seemed to spin freely enough for a couple of rotations then slowed to a stop. Anyway removed front wheel and dust seals and one of the bearings was definitely on it's way out, very gritty to turn between fingers and had slight rust deposits on it. I fear this has been my fault as when I got the wheels powder coated I had to put in bearings before I could have the tyres fitted... However I washed, dried and sealed the wheels before putting them on the bike... I obviously got water on the bearings... every day is a school day, won't be doing that again!
Anyway, New bearings in and refitted front wheel, lightly spun it and thought it was never going to stop spinning!! A huge improvement! Put the calipers back on and the wheel didn't spin much because of the resistance from the pads. Took it for a run and still the same problem although not so sure it's a pulse through the lever as much as just juddering and shaking the front fairing and mirrors and feeling it through the pegs and frame...
Shame it hasn't helped but I'm glad I changed it as it was definitely needing it!
I'm going to replace the rear wheel bearings as they were also washed before being refitted and the chance of one of them being rusty etc is fairly high and for my own piece of mind I want to replace them. It might make no difference to my problem but then it might, if the rear wheel bearing isn't happy then by using the front brakes the weight is taken off the rear wheel so if it's resonating and not turning right it could be translated to juddering through the frame... maybe...
Not going to have a chance to do anything with the bike for the next week but will let you all know if I come up with anything. Pad retaining springs also arrived today darrsi but didn't have a chance to try that as I'd already started the bearings and just wanting to change one thing at a time so I know what the problem has been.
Chris
[Image: 208008.png]
That's definitely a must only doing one thing at a time otherwise you'll tie yourself up in knots.
Springs got to you quick, fair play to the postal service.  Smile
(29-08-15, 06:47 PM)darrsi link Wrote: That's definitely a must only doing one thing at a time otherwise you'll tie yourself up in knots.
Yeah, they did a good job! Thanks for posting them so quick, just ran out of time to swap them and try them today.
Chris
[Image: 208008.png]
(29-08-15, 06:59 PM)Chris link Wrote: [quote author=darrsi link=topic=18057.msg208455#msg208455 date=1440870421]
Chris
I really don't think they'll help at all to be truthful, but at least it'll be another thing to rule out.
Good luck in sorting yer bike mate keep us informed :thumbup
omnia causa fiunt
Did you get to the bottom of this Chris?
Hey darrsi,
Unfortunately not had a chance to get near the bike since my last post. Ill health and then working a lot of extra night shifts at the moment just haven't had the time. Weather is looking better the next few days and I finally have some time off so might get a chance to do something with it. The nice weather might be spent giving the cars a good deep clean and protection before winter sets in though!
Cheers,
Chris
[Image: 208008.png]
I've had front brake judder on mine at times, as the bike slows under braking it starts as speed drops to about 20mph and gets worse as it comes to a stop, the only thing I can put it down to is washing the bike and getting detergent/ washwax/ insect remover/polish on the discs, I only wash it now in winter if it's salty and Im careful not to get any cleaners on the brakes and this has stopped the juddering.
I mainly use Mr Sheen for cleaning the insects off now although it might take a couple of goes if they dry on and WD 40 to get any chain lube of the rear wheel/swingarm, making sure not to spay near the brakes, spray it onto the cleaning cloth when near the discs, hope this helps.
PS still on original pads with 44k miles on the clock.
(28-09-15, 09:44 PM)chaz link Wrote:I've had front brake judder on mine at times, as the bike slows under braking it starts as speed drops to about 20mph and gets worse as it comes to a stop, the only thing I can put it down to is washing the bike and getting detergent/ washwax/ insect remover/polish on the discs, I only wash it now in winter if it's salty and Im careful not to get any cleaners on the brakes and this has stopped the juddering.
Crikey you must brake like Fred Flintstone with your feet!  :lol
(28-08-15, 11:12 AM)darrsi link Wrote:I find the simplest way to check if head bearings are maybe loose is by having the bike on the ground, push it forward a bit then pull hard on the front brake lever.
Another easy way to check your steering head bearings (A little more subtle  :eek )
Lift the front wheel off the ground (on centerstand and sit someone/thing on the pillion seat probably easiest)
Gently turn bars from full lock to full lock. If there is any play in the bearing it will self centre. (Kind of drops into the centre with your wheel pointing straight forward)
Not very exciting was it, but effective!
(28-09-15, 10:55 PM)joebloggs link Wrote:[quote author=darrsi link=topic=18057.msg208361#msg208361 date=1440756741]
Or let me ride your bike, I'll whinge like mad.  :lol
