these are the inputs and outputs
not working.....try something else.
Coolant hoses on Carburator
these are the inputs and outputs not working.....try something else.
13-05-15, 05:38 PM
To answer your original question yes you could block/disconnect the carb heater hose without any problem or damage to the carbs/cooling system or any other part of the bike.
But there would be no real benefit because once the thermostat has opened as the bike warms up there is effectively no flow through the carb heater pipes. You can confirm this by checking the temperature of the pipes at the carburetors and they never even feel warm to the touch. |
« Next Oldest | Next Newest »
