weave /wobble
#21
Nice evening for a bit of fazer fettling  Smile.......took the swinging arm off...shock linkage all ok, a bit grubby but ok, will give it a clean and re-lube.....ive got a bit of play in the swinging arm bearings, not sure how much is acceptable but will change them to make sure...wemoto list a kit for £28 +p&p...makers name....slinky glide.....not heard of them before and not a term ive used for a very long time  :lol
.jpg   20140519_193812.jpg (Size: 154.38 KB / Downloads: 86)
bin that red dangly bit
Steady on......that red dangly bit has served me well.........ah...your on about the shock aint you  :o......when funds allow i'll pm you  Wink
Red...some geezers on here recommended me a bearing company, proper engineering place,  i can concur that they are worthy....it was something like marksman, defo had like a target for its logo......anyhoo they were about 10 earth pounds each which is a good saving.
Ill try look for the receipt to save you endlessly searching through old threads.
Actually i may search "noggythenog" & swingarm & find the old post.
Just bear with me a little bit.
.jpg   image.jpg (Size: 19.97 KB / Downloads: 80)
This is the one
http://shop.marksman-ind.com/motorcycle-...uk-2-c.asp
Great to deal with
Cheers UNFAZED......dont know whats happened to MR NOG.....parhaps hes lost his bearings  :rollin
Maybe he is outside looking for the spider to check the WEB site :lol
Oh how i chortled :rollin :rollin :rollin
Sorry red.....i had to watch that bear gryls  survival thing & then things happened....n stuff............unfazed was it you that recommended me them in the first place or did you just do a search?.......im sure it was you...if it was then sorry for not remembering......bad drills really aint it.
But has red saved any money....thats what counts.......fast bike discount
Yeah, it was me, but it is ok, I can handle it.
no probs MR NOG.......fazer thou not shown on web site,have emailed them,looking at the other yam bearings its looks like there will be a small saving.£4 ish for both....if i dont get a reply by tonight i`ll order from wemoto,they have them in stock and are quick to deliver  Wink
(19-05-14, 09:10 PM)unfazed link Wrote: This is the one
Great to deal with
I used them for my r1 front end bearings. Ask for mark. Very helpful guy and they arrived the next day.
mmmmmmmm.....look what i've got...
.jpg   20140521_175243.jpg (Size: 48.01 KB / Downloads: 67)
Where is the collar/bush?
Not included with this kit.....swing arm is a bit different to wheel spindle.wheel has center spacer and two sleeves/collars that run on the roller wheel bearing, on the swinging arm these three pieces are one.....old one was very good so I cleaned it up and re-lubed....
Fitted the new bearings tonight.......my drift was'nt going to work, not enough room to get it in there, so I prised the rollers out and removed the plastic roller carrier from both sides I then used a length of 22mm copper tubing to knock the outer bearing casing out.....worked a treat  Big Grin.......cleaned everything up and pressed the bearings in square with my hands just to get them started, I then used a sash cramp to push them all the way in, then using a scoket slightly smaller than the bearing for the last little bit
Dropped the spindle in and no play what so ever  Wink.....will put it back on the bike tomorrow.
.jpg   20140521_194919.jpg (Size: 172.42 KB / Downloads: 57)
.jpg   20140521_195407.jpg (Size: 110.62 KB / Downloads: 57)
.jpg   20140521_194701.jpg (Size: 175.39 KB / Downloads: 58)
You just cannot beat improvisation, it's the mother of invention. Smile
Are you going to patent that bearing tool :lol
Are the frame rubbers covering the Spindle in good condition. Put some grease inside them to stop and water ingress and don't forget to grease the bearing covers.
Enjoy the test run tomorrow Smile
Pat applied for  :lol....this time next year I'll be a millionaire  :rollin......yep..both caps in vgc.....will be well greased, thanks for the tip....bearing covers already fitted and packed with grease..... Smile
Nice one Red,  noticed a bit of play on my swing arm the other week,  tightened up the nut and it's better but still a bit of play. Will refer to this post when I attempt mine.  Cheers.
hi dazza....its an easy job,bearings under £30....roller bearings , so nipping your nuts is not really going to work  :\ ...all being well i`ll have it all back together tonight and have a test ride .....
All back together tonight and out for a test ride....very smooth and stable  Big Grin.........well done CRH..for guessing correctly you have won a prize  Wink
