Date: 02-05-26  Time: 03:43 am
Author Topic: Ohlins  (Read 2424 times)
snave
Ohlins
« on: 09 September 2013, 08:45:01 am »
Hi all, I've recently put on a ohlins rear shock, anybody know how many clicks rebound and compression should be as a starting point?
Cheers
Lyndon
Falcon 269
Re: Ohlins
« Reply #1 on: 09 September 2013, 12:53:33 pm »
Gen 1 or Gen II?
Your weight?  Solo or two-up, mostly?
The spring rate of the shock.  Is it standard (0.85) or something stiffer/softer?
Welcome, BTW :)
steeeve66
Re: Ohlins
« Reply #2 on: 09 September 2013, 01:36:24 pm »
did you get the shock with the remote preload adjuster? pretty sure i've got the manual for it and will ping it over if you like (it's on Ohlins' website though I think...)
shrekster
Re: Ohlins
« Reply #3 on: 10 September 2013, 12:32:05 pm »
Check the Ohlins website I'm sure they have set up info for all the bikes they cover.
Jim.
snave
Re: Ohlins
« Reply #4 on: 10 September 2013, 03:17:50 pm »
It's a Gen1 with out remote preload , I've changed the spring to match my weight, just wanted base settings to save me clicking adjusters for weeks
Falcon 269
Re: Ohlins
« Reply #5 on: 10 September 2013, 03:28:44 pm »
Mine's got the remote reservoir and preload so not the same model.  Sorry, can't help with base settings for yours.
ogri48
Re: Ohlins
« Reply #6 on: 10 September 2013, 03:48:49 pm »
You could give matey a ring at MCT. He knows his stuff. As mike says, welcome by the way...
Re: Ohlins
« Reply #7 on: 10 September 2013, 04:41:34 pm »
May be able to help me out though Mike (again)     13.5 stone rider with kit, standard spring, mainly solo, occasional pillion, occasional luggage. :)
Falcon 269
Re: Ohlins
« Reply #8 on: 10 September 2013, 08:36:32 pm »
Will need to check the spec sheet K-tech supplied me when I bought the shock from them.  Have no idea where mine is actually set now after a few tweaks, though.  Not more than 2 - 3 clicks off the baseline, I suspect.
I'm always solo riding and lighter than you by a stone in riding gear.
I'll get back to you soon. :)
