Date: 01-05-26  Time: 05:57 am
Author Topic: Clicking sound from the rear?  (Read 2332 times)
bigfootpete
« on: 11 August 2013, 10:10:45 pm »
Hi all,
So I got the dealer to fit my head bearings, while he was doing it he noticed the chain needed tightening but said that
one of the nuts was "seized".
I checked when I got home and adjusted it no problem, although I have noticed that when I got back from my ride this afternoon
that there is a clicking noise coming from the back wheel hub.
Does that sound like something I need to worry about?
Chain and sprockets are on 36,500 miles and still five marks left on the swingarm, although I guess they are due to be changed...
Falcon 269
Re: Clicking sound from the rear?
« Reply #1 on: 12 August 2013, 04:37:28 am »
C&S are probably well past their best at that mileage.  Any hooking will cause clicking noises, same with tight links.  Fella on thte US forum has just broken his crankcase through having a worn chain jump the front sprocket.  I'd change it soon ...
http://www.yamahafz1oa.com/forum/showthread.php?t=129143
While you're waiting for the new C&S to arrive, check the rear wheel bearings.
R1FSR
« Reply #2 on: 13 August 2013, 05:09:20 pm »
Another thing to look at is ....if he adjusted your chain , did he do it with you sat on the bike ?
if not it could have been made worse by the time your actually on it , I made this mistake with mine
although the clicking/knocking noise actually came from the front sprocket area .
its poss to tight now
Capt
« Reply #3 on: 13 August 2013, 07:26:48 pm »
Had a similar noise from my front sprocket, decided to try the 15T only to find the sprocket nut was only hand tight. Bike had covered 13K with a bearly tightened front sprocket, thank god the lock washer held up.
bigfootpete
« Reply #4 on: 15 August 2013, 09:21:39 am »
Ahhh, it was probably my fault, may have tightened the chain too much, I'll re-adjust on the w/e, thanks!
bigfootpete
« Reply #5 on: 18 August 2013, 04:23:56 pm »
Ok, it's definitely not the chain, the clicking is coming from the hub of the back wheel... it's not constant either...
Any more thoughts?
