Date: 07-05-26  Time: 23:46 pm
Author Topic: Chain and sprocket question  (Read 9319 times)
bellycgb
« on: 26 July 2013, 06:59:11 pm »
OK so ive just bought this DID chain and sprocket kit from ebay :- http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=321040757202, it arrived today and a couple of things puzzled me,
the front and rear sprockets are different brands - powerite front  and jt back, is this normal?
the auction says its a VXBG chain with is the heavy duty one but on the chain itself it says VX which is the standard one? any other way to tell what chain you have?
have a look
elbrownos
Re: Chain and sprocket question
« Reply #1 on: 26 July 2013, 07:55:53 pm »
I've never bought a chain so I'm no expert but a quick google leads me to believe GB means gold & black, not heavy duty.
Heavy duty is just what they call their chain that isn't gold & black.
That ad is definitely for gold & black chain (which costs more) so you've been had.
Wouldn't worry about the sprockets though.
Punkstig
« Reply #2 on: 26 July 2013, 08:45:21 pm »
The DID VX is a heavier duty chain to standard, and are very good, I tried the zvm-x extra heavy duty and it only lasted the same for me so isn't worth the extra (in my experience)
JT sprockets are good, not heard of the other one you've been given but there is no issue having different makes front and back!
bellycgb
« Reply #3 on: 27 July 2013, 08:09:50 am »
The chain in black and gold never realised that's what the GB part was lol  :rollin
Cool that's good to know
CharlieDee
« Reply #4 on: 27 July 2013, 08:20:27 am »
Hope you like cleaning your chain!! As it doesn't stay gold for long!!  :grumble :smokin
« Reply #5 on: 27 July 2013, 09:17:23 am »
After you've been for a ride and lubed your chain, spray brake cleaner on a rag and rub it over the visible side of the chain, without soaking it, and it'll look like new in no time!  :D
CharlieDee
« Reply #6 on: 27 July 2013, 09:46:08 am »
Cheers for that Darrsi... I shall give that go!!  :smokin
« Reply #7 on: 27 July 2013, 09:56:43 am »
You're just cleaning the outer though, so don't soak it enough to get into the rivets otherwise you'll dry it out.
CharlieDee
« Reply #8 on: 27 July 2013, 10:09:58 am »
Roger D  :lol
bellycgb
« Reply #9 on: 28 July 2013, 09:27:54 am »
The first of many shiny new parts to be fitted. Operation phoenix is GO!
Punkstig
« Reply #10 on: 28 July 2013, 09:37:21 am »
WD40 will clean the outer plates with no risk of stripping lubricant like the brake cleaner could!
CharlieDee
« Reply #11 on: 28 July 2013, 11:07:54 am »
WD 40 is what I tend to use... only prob with it is, it usually attracts dust and crap... well IMO  :rolleyes
Punkstig
« Reply #12 on: 28 July 2013, 01:11:55 pm »
It leaves a coating on anything which attracts all kinds of crud, but then cleans off easily again, we're talking about a chain here, IMO its supposed to look black and oily!
« Reply #13 on: 28 July 2013, 01:17:59 pm »
But gold is pretty  :D
Dead Eye
« Reply #14 on: 28 July 2013, 07:21:41 pm »
Pretty much my mind set as well :P Just keep mine topped up with lube and clean it when it gets a bit too pastey :P
Lawrence
« Reply #15 on: 06 August 2013, 12:10:36 pm »
The entire left side of my swingarm is black, let alone the chain   :look  :D
BluprintZ
« Reply #16 on: 09 August 2013, 11:12:40 am »
Took the sprocket cover off mine yesterday, been getting noises and vibes through the footrests that pointed to a possible worn chain and sprockets, plus i was rather paranoid about the sprocket nut loosening problem.
Happy days, the sprocket nut is tight but both the chain and sprockets are due for replacement, boo!
Cleaned all the crap out of the cover and around the sprocket, discarded the cover gasket, which was in bits anyway and re-fitted the cover and made the necessary adjustment to the clutch to compensate for the missing gasket.
My chain cleaning routine has usually been a case of cleaning the chain with WD40, then wiping the excess off with a rag, then using a paintbrush to grease the chain with LM grease, i really don't like the spray type chain lubes, maybe i'm just old fashioned?
Anyway, just about to order the 12mm front sprocket nut and tab washer and a new chain and sprocket kit.
G ; )
