Date: 05-05-26  Time: 15:25 pm
Author Topic: Engine oil  (Read 28653 times)
Re: Engine oil
« Reply #50 on: 18 July 2013, 10:29:44 pm »
Simon.Pieman/VNA: I have used car oil (and not the cheapest) in bikes and regretted it… not that the engine actually broke as a result, but power gradually dropped off as the cam lobes suffered excessive wear.
 Castrol GTX (white can) is not strictly a car oil, it was advertised in bike magazines and MCN for many years as the stuff to put in your bike.
As for cam wear, how do you know it was the oil? many many bikes have suffered endemic cam lobe wear which is usually a hardening issue. I had a GPz900 in the eighties and almost the entire production run of the first model had premature camlobe wear for example.
Yes, it would be useful to know if this (cam lobe wear) problem was definitely due to the oil you used, and how you can be sure of this?
True, I can't prove it wouldn't have happened anyway.
I should have kept an identical bike running on Silkolene and ridden them alternately. Remiss of me.
As it stands it is only anecdotal evidence, it was enough to convince me that saving perhaps £2 per thousand miles isn't worth the risk.
Hedgetrimmer
Re: Engine oil
« Reply #51 on: 18 July 2013, 11:03:39 pm »
Hey, no one's having a dig at you here - you might have some useful information from your experience. Did you only use this oil with one bike, or more than one? If only one, ok, it's possible the oil had something to do with the problem. If more than one, and only one bike had the problem then possibly the oil wasn't to blame on balance. Was it a bike model known to have such problems anyway? So that narrows it down a bit more. So then you think, did anyone else use this oil in a bike and have the same problem? Simple deduction process. But you'll already have filed some of this info away, so when you see a similar problem or comment in the future, that's another piece in the puzzle. By the way, I'm not grilling you here, it's just that some people seem to get very frustrated with what is after all just a discussion, in my opinion an interesting one, maybe not in your opinion. So then, you don't have to get involved; add your information to the fund and leave it to boring old gits like me to pursue it if that's what we like to do :)  As to spending the extra for what you know and trust, that's exactly what I do. :) :) And I don't mean to sound at all condescending here - maybe my wording could be a bit better.
Re: Engine oil
« Reply #52 on: 19 July 2013, 12:17:50 am »
Oops! Meant to stick a smiley at the end of the second line of my last post, forgot, and what was meant to be mildly humorous ended up reading like I was having a hissy fit.
I was just trying to make the point that Simon's request for examples of problems caused by car oil being responsible for bike engine failure being followed by a demand to prove it was a bit pointless. From a statistical point of view, there won't be enough data to establish a causal link even if every member of this forum contributed detailed account of every bike they owned, mileages and oil used.
A blind test with two identical bikes alternated regularly between two riders and run for say, 50,000 miles each and followed by a forensic examination would offer much more convincing evidence whether or not bike oil is just car oil with the price jacked up. "Ride" magazine used to do various long term tests, but so far as I know that isn't something they've attempted.
In the absence of scientific studies I'd tried to look at the problem from the other direction. That is, that it's obvious that the oil has a tougher environment in a bike than it does in a car. So, oil companies would hardly limit themselves to ripping off thousands of bikers on the one hand yet supply millions of car drivers with oil that is way better than it needs to be for their purposes. Therefore car and bike oils must be different.
Hedgetrimmer
Re: Engine oil
« Reply #53 on: 19 July 2013, 12:28:23 am »
For me , there's never been any argument that car and motorcycle oils are, and need to be, different. I'm not so cynical that I disbelieve everything the oil companies say. I also wouldn't discount claims of improved fuel consumption and increased power output totally. But as Slaninar says, those benefits may be minimal. The oil companies make vast profits as we all know, but they also stand to lose a great deal if found to be making false claims. Your way of approaching the problem is a much more practical solution from our point of view. But I never thought I'd find the subject so fascinating - must be getting old!
Dave48
Re: Engine oil
« Reply #54 on: 19 July 2013, 05:21:30 am »
Its difficult to separate the solid facts from all the marketing hype but in the final analysis I want to know that my oil meets the required JASO/SAE standard for the engine its being used in. The viscosity range depends on local climate eg 10W-40 in my Fazer in UK. I am told to avoid friction modifiers and detergent rich oils(as used in diesel engines to keep product of combustion particles in suspension). So now I am looking at  oils designed-yes designed-for use in motorcycles-ie high revving,high specific power output(BHP per Litre) with lubricant shared by engine,clutch & gearbox. If I saw such oil for sale in any outlet(Wilkos Asda Tescos etc) I would have no qualms buying it.
if I do 3000 miles per annum on my bike & change the oil & filter every year its not going to be a costly exercise if I look for the supplier offering the best deal for what I want. If Yamaha specify a certain standard for oil that's good enough for me. The reason for the annual change is simply that my bike doesn't get used much in the colder months & cold storage can lead to condensation & acid build up in  cold damp conditions. I am quite sure the oil would be good for the full 6000 miles use were I to ride all year round.
There have been various reports published about cars being driven for extended periods (20000 miles) between oil changes and there is a school of thought that suggests this isn't necessarily a good thing-but being a bit cynical this may just be the oil companies trying to shift more product!
I know my local Yamaha main dealer uses Motul oil because I have seen the empty 205Litre drums in their recycling area. I think if I did a massive mileage I would look to buy my oil of choice in bulk to reduce costs but its going to take me a long time to get through that much! :lol  In the last 10 years have used Silkolene ,Motul, Yamalube and Morris Lubricants-all 10W-40 Semi synthetic in my bikes. The car gets whatever the garage uses at annual oil change-regardless of mileage as I do less than 10000miles per annum with a lot of short journeys-top up if required is with Halfords own brand or similar. The only fully synthetic oil I use is for the leaf blower/vac & strimmer as stipulated by their manufacturers so the 1951 Cycclemaster also benefits from this oil-with minimum smoke & leaned out ratio (33:1 instead of 25:1).
Don't think I would try anything in the bikes that I wasn't sure about(or as sure as any of us can be in this age of information (bullshit?) overload but Im just a cynical old git!
Slaninar
Re: Engine oil
« Reply #55 on: 19 July 2013, 05:49:56 am »
I agree with most of what you've said in this topic. I came to the local mechanic (a good one) with the brilliant idea:
"Why wouldn't I use non-motorcycle specific oil? It says API SG on the can, just like Yamaha recommended."
He told me that "car" oil is good enough for low revving, low power bikes, but not to put it in the Fazer. Then I talked to 2 guys who work with oil companies (one was a chemist, the other just plant engineer). Took it all with a grain of salt, but all those people have recommended motorcycle oil. They also agreed that  mineral oil is not very good. They also said that although full synthetic oil IS the best in terms of protecting the engine, best thing for a fazer is a semi-synth (in terms of money-value).
As far as brands go, the oil guy that was a chemist works for Fuchs (Silkolene) recommended Silkolene, but he said Motul was just as good. The other, non-chemist guy recommended Motul as number one. Both said they don't have enough info on US brands (Bel Ray, Bardahl, Amsoil).  The mechanics I talk to swear by Repsol.
I've used full synth oil in old 1997 (80s tech) Suzuki GN 125. In Fazer as well. Engines look like brand new from the inside - no grime, no problems. I stick with it. Costs 10e more per change for the fazer.
One more thing. Fazer uses 2.7 litres per oil change, while full oil capacity on stripping the engine is about 3.4 litres. Which means you always have around half a litre of old oil diluted in the engine. One more reason to use good, long lasting synthetic oil IMO.
Hedgetrimmer
Re: Engine oil
« Reply #56 on: 19 July 2013, 09:12:25 am »
Yes, Motul is the Yamaha recommended oil. They're not going to recommend anything that's not good for your bike. When I was younger, I was pretty lazy about oil changes (we're talking 20-odd years ago, so I suppose I'm not that old - just feel it!). This includes in my old 750 Turbo (some of you may have gathered by now I have fond memories of that bike!), and turbos do put a very high strain on oils - they actually glow red hot. There was talk at the time that if you just shut off a turbo engine immediately after hard use, the oil would crystallise in the compressor bearing and knacker it. Don't know how true that is, but I always used to think that because my rides always finished with a slower bit at the end (residential streets going home etc), that's why I never had that problem. Nowadays I wonder if that isn't so much bullshit. But oils have come a long way since then, and even then I had no oil related problems.
Re: Engine oil
« Reply #57 on: 19 July 2013, 11:36:50 am »
The cynic in me says they're more likely to recommend something which involves a lucrative deal with an oil supplier who'll give them a kick-back for plugging their product...
Hedgetrimmer
Re: Engine oil
« Reply #58 on: 19 July 2013, 11:44:49 am »
Yeah , well, that's pretty much a given I'd say, but even so....
Slaninar
Re: Engine oil
« Reply #59 on: 19 July 2013, 11:45:30 am »
Grahamm, did you just say "Yamalube"?  :)
VNA - BMW Wank
Re: Engine oil
« Reply #60 on: 19 July 2013, 06:27:59 pm »
Going by the specs what we are putting in our bikes is pretty basic oil, long ago considered obsolete in the car manufacturing world.
Oil companies are notorious for making false claims, not to mention many other nasty habits that many of em have.  It's pretty much in their interest to confuse you anyway.
Did somebody say Turbo Charger?
Well it's becoming increasingly hard to buy a car that doesnae have one.  As I said earlier have a look at the specs for the latest small capacity petrol engines that some of the big cars firms are now producing.   They are pretty impressive engines!
Think also what a car has got to do.  A bike engine has a far easier job at the end of the day.  Look at the torque figures that many modern cars are now producing.  And yes consider that there is a turbo in there along with far tighter emission standards and that car companies are chasing 24mnth 30,000 mile service intervals now.
But of course just becuase your average car oil is far more sophisticated than your average motorcycle oil does not mean it will be good for your bike.
And if you want to start another thread that will generate similar amounts of general bull, try something like - will I get more power and better mileage running my Fazer on 98RON fuel?  (before you do the answer is no and no.)
At the end of the day, semi-synth is fine, check the spec in your bike manual, buy a tin of oil quoting that spec and to be on the safe side make sure it has a picture of a bike on the front of it.
I'd would suggest for new or low mileage bikes you avoid fully synthetic oil for a good while, as there is a small risk you polish the bores and end up with piston rings that won't scrub in.  (some may say that this is another internet myth - I dunno)
Now if you are determined to beat the oil companies, and save a few bob, with a bit of research you may well come up with something better and cheaper.
Slaninar
Re: Engine oil
« Reply #61 on: 19 July 2013, 07:26:32 pm »
For the first 10.000 kilometers it is good to run the bike on semi-synth. Except for bikes that come with full synth from the factory (most new ones do).
VNA - BMW Wank
Re: Engine oil
« Reply #62 on: 19 July 2013, 08:30:20 pm »
I was of the understanding that most bikes come from the factory filed with a low spec mineral oil.  It aids bedding in and hence the usual 600 mile oil and filter change.
The late Kevin Ash on running in - http://www.ashonbikes.com/content/running
Peter Brett in that article from Castrol oils;
Peter Brett says that they’ve discovered synthetic oils actually interfere with running in, for reasons which go beyond their low friction properties - there also seems to be a chemical process happening which hinders it. “Although you can treat an engine as fully run in after 500 miles, surface stabilisation continues for at least the first 5,000 miles of an engine’s life,” he says. “Synthetic oils actively prevent this from happening, and not simply by holding friction surfaces apart, although we still don’t know exactly why and how this happens. But there’s no doubt they inhibit the process itself. So the consequence of using a synthetic too early is your engine will never run in properly. I would even suggest waiting until 10,000 miles (16,000km) before using it in most engines subjected to normal use. Until then, you’re best to use an inexpensive but branded mineral oil.”
Hedgetrimmer
Re: Engine oil
« Reply #63 on: 19 July 2013, 08:39:58 pm »
I used to do PDIs on new bikes as a Saturday lad (early 80s), and a relatively small amount of low spec oil is all the bikes were delivered in the crates with. On a PDI, you'd drain that out and fill up with the proper oil. Don't know if it's all changed now tho.
Excellent article, fascinating. Thanks for the link VNA.
VNA - BMW Wank
Re: Engine oil
« Reply #64 on: 20 July 2013, 02:13:35 pm »
As I was oot in the garage there, I thought I'd check the spec of the bike oil that I'm paying a pretty penny for.
In the bike at the mo is Fuchs Silkolene Super 4 (semi synth) 10/40 The API spec is SF and SG.
In the bike last year was Fuchs Silkolene Comp 4 (fully synth - dunno why, shop must have given me fully synth for the price of semi by accident) The API spec is SG,SH and SJ
In the car is Unipart Pro P100 10/40 (I get my bits for the car direct from the Unipart distributer - great prices!).  The car is a 2002 VW Bora 2.0  It is not the recommended oil but it's done 70,000 miles so far on it.  The spec is API SL/SJ/CF
If we look up the API web site;
Super 4.   We can see that SF and SG are obsolete.  SF for 1988 and older engines.  SG for 1993 and older.
Comp4.   SG and SH obsolete.  The final spec that it meets is SJ.  Hurrah! It meets a current spec, recommended for engines 2001 and older.
Unipart P100 - SL,SJ and CF  SL - current for 2004 and older.  SJ - current for 2001 and older.  CF obsolete 1994 for all road in-direct injection diesel.
So there we have it.  The Fuchs motorcycle oils are basic spec lubricants, certainly not the kind of stuff you'd want to put in a modern car.
The cheapest oil here - by a country mile, is the Unipart P100, is the highest spec and ideal for many modern cars.
Now whilst clearly the P100 is a more sophisticated high spec oil than the basic SF/SG muck that I'm currently putting in the bike, well the problem is again that, as we have seen above, putting too high a spec oil in your engine can cause problems.  Then there is the issue of the pesky friction modifiers, how can we be sure they are not present?
I would suggest that the usual statement that motorcycle oil is higher quality oil than car oil, well it's another internet myth.  The opposite is true.
And yes sadly, to get the cheap basic spec oil we need for our bikes, we have to pay through our nose.
Hedgetrimmer
Re: Engine oil
« Reply #65 on: 20 July 2013, 02:27:32 pm »
I guess if you're an oil producer, you'd be thinking, well, we sell millions more litres of car oil than bike oil, so we'll invest more in research and improvement for the former, and as long as the latter more or less keeps up with engine technology, well it's unprofitable to spend too much time and resources on it?
What are the world's top bike racing teams using? Is it what we buy?
VNA - BMW Wank
Re: Engine oil
« Reply #66 on: 20 July 2013, 02:28:34 pm »
The other spec listed on the Fuchs oils JASO MA  (MA2 I think)
Japanese Automotive Standards Organisation.
MA is your guarantee that the oil is suitable for wet clutch use.
My conclusion.  Probably as confused as you are.
Hedgetrimmer
Re: Engine oil
« Reply #67 on: 20 July 2013, 02:30:27 pm »
Sorry VNA, crossed your last post - added something to mine.
VNA - BMW Wank
Re: Engine oil
« Reply #68 on: 20 July 2013, 02:39:28 pm »
They make the oil that the automotive manufacturers demand.  They in turn have been driven by emission standards.  So it's driven by standards.
It doesn't look as if the oil you put in your bike has changed much since the late 80's.  In the car world it's changed considerably.
We may yet see advances in motorcycle oil as emission standards are tightened up again.  Just the same as for cars, if the manufacturer demands a high spec oil, the oil producer will come up with the goods and it'll go in your bike.  If not we'll continue with basic oil that hasn't changed much since 1988.
There is also the 'not been tested to the latest standards' thing that is quoted on the web.  Another internet myth I suggest.  If Yamaha asks for an obsolete API oil, that is exactly what the oil company will deliver.  No more no less.
Whatever you do, do not put bike oil in your car!
Doddsie
Re: Engine oil
« Reply #69 on: 20 July 2013, 11:16:42 pm »
Ive got a bloody headache now!!!!! :\
Hedgetrimmer
Re: Engine oil
« Reply #70 on: 20 July 2013, 11:46:00 pm »
Serves you right - look what you bloody started! :lol
Jacko
Re: Engine oil
« Reply #71 on: 21 July 2013, 09:59:20 am »
The way I see it, it's a bit like tyres.
Handbook for my '98 600 says use radial tyres of correct size,
now this doesn't stop me using the best tyres I can get as things have developed and improved in
the 15 years since my bike was made.
For oil it says use motor oil of a certain spec. Now if i meet this spec, great, if I surpass this with a super
oil of the 21st century then also great.
So meet the minimum and everything else is up to you.
VNA - BMW Wank
Re: Engine oil
« Reply #72 on: 21 July 2013, 10:17:36 pm »
OK, here we go again.
Yamaha quotes obsolete API specs as recommended oil.  These are specs that date back to the 1980's and 90's.
As far as I know all the genuine motorcycle oil on sale in the UK is manufactured to obsolete API automotive standards.
Feel free to fill your bike with the latest super high tech API SM, but you might not feel so great once you find your clutch is wrecked and you need to get your bores honed and new rings fitted.
I mean you could fill your tank with a higher spec fuel such as methanol, but you know, I don't think it will get you far.
chaz
Re: Engine oil
« Reply #73 on: 21 July 2013, 10:55:26 pm »
About 10 years ago I was doing some building work for someone who supplied oil to the F1 racing teams, what he told me was that the oil they used was different than what you buy, and cost much more something like 5 times as much, don't know if this is the same in bike racing, anyway on a ride out of say 150 miles how much of that is your engine revving at over 12,000 rpm, not that much or if it is I want to know that ride 8)
Jacko
Re: Engine oil
« Reply #74 on: 21 July 2013, 11:26:55 pm »
Andy, thats my poorly made point. Minimum spec is fine.
I'm trying to say minimum is good, above that for pretty bike pictures or semi synth
or fully synth is just choice and cost.
I'm a Wilkos 10-40 guy and at 73K miles the bikes fine.
