Date: 05-05-26  Time: 10:12 am
Author Topic: Engine oil  (Read 28638 times)
Doddsie
Engine oil
« on: 16 July 2013, 01:55:25 pm »
Just been to local car parts place, 10w40 semi synthetic motor oil, 5L - £19.99.  10w40 semi synthetic MOTORBIKE oil, 5L, same brand - £29.99!!!! Whats the difference???
Hedgetrimmer
Re: Engine oil
« Reply #1 on: 16 July 2013, 02:02:59 pm »
http://www.mobiloil.com/USA-English/MotorOil/Car_Care/AskMobil/Differences_Between_Car_and_Motorcycle_Oil.aspx
...should answer that. To my knowledge, you should never use a car oil in a motorcycle engine. I'm guessing that a major part of the price difference will be due to production costs - millions more cars than motorcycles out there.
Slaninar
Re: Engine oil
« Reply #2 on: 16 July 2013, 02:05:52 pm »
Aditives, composition and marketing.
Motorcycle engines as well as clutches are not the same as car ones.
Make sure it is API SG and JASO MA2 approved.
Punkstig
Re: Engine oil
« Reply #3 on: 16 July 2013, 02:25:40 pm »
As the others said, motorbike oil has many different properties to car oil, the main one being the wet clutch.
Tmation
Re: Engine oil
« Reply #4 on: 16 July 2013, 03:10:03 pm »
With a caveat of you have to be careful what you buy i.e. no friction modifiers and it meets the standards previously mentioned, car oil is fine.
I ran my GPZ1100 for nearly 80,000 miles on cheap Ford motor oil (my dad got big discount) changed with a new filter every 3000 miles with no problems whatsoever. When he was working my dad used to run all his bikes on he same oil (CB750,CB550,CX500,CX650) for years.
Supermarket own brands are also good value as long as they meet the spec.
Slaninar
Re: Engine oil
« Reply #5 on: 16 July 2013, 05:22:21 pm »
Motorcycle specific oil is better. Good motorcycle oil vs good car oil that is.
Differences are:
1) Revs
Motorcycle engines rev a lot higher. This asks for more anti-foaming qualities in oil. It also breaks the viscousity of oil down quicker - so it should be "tougher".
2) Power to capacity ratio
600 cc fazer engine makes almost twice the hp of a 1200 cc car petrol engine. Add a bit higher working temp, greater compression ratio. This also asks for a "tougher" oil and makes most purely mineral oils just not good enough.
3) A lot mentioned wet clutch - motorcycle oil should make good scratch protection inside the engine, witout making the clutch too slippery. If oil is JASO MA2 approved - it does just that perfectly.
Changing good motorcycle specific oil every 4000 miles is better for the motorcycle engine than changing car oil every 3000 miles.
Jacko
Re: Engine oil
« Reply #6 on: 16 July 2013, 06:50:32 pm »
Mr Yamaha says SE , SF type or equivalent and don't put any additives in.
No mention of car or bike just the spec.
VNA - BMW Wank
Re: Engine oil
« Reply #7 on: 16 July 2013, 06:53:24 pm »
Often it is no more than the label.
But if you do use a car oil you need to be sure there are no friction modifiers.
VNA - BMW Wank
Re: Engine oil
« Reply #8 on: 16 July 2013, 06:57:02 pm »
Quote
Often bike oils quote older lower specs than car oils.  Could be due to the cost of type approval tests.  I dunno.
Some of the latest long life car oils are very high tech.
But again the trick is being sure a friction modifier is not present.  One dose of that and you'll need a new clutch.
But basically, yes bike oil is a big rip off.
Slaninar
Re: Engine oil
« Reply #9 on: 16 July 2013, 09:39:46 pm »
It also says 10k kilometers oil change intervals - too much.
Better is better. For a high revving fazer engine, I wouldn't risk putting anything but bike-specific semi or full synth oil.  Too much risk for a max 10e save per oil change.
Hedgetrimmer
Re: Engine oil
« Reply #10 on: 16 July 2013, 09:44:31 pm »
Yamaha used to recommend 4000 mile oil changes for most of their range. Then, a few years ago, they changed to 6000 miles. This applied retrospectively to some models. I guess they got more confident in their engines and/or modern oils. I'd say if you thrash your bike everywhere or maybe operate it in constantly in hot climates, 4000 miles might not be unreasonable. But generally, 6000 miles should be fine with modern oils.
Fully synthetic oil is not really necessary in most road bike engines. In some engines it can cause clutch slip, although I believe Ducati recommend it for their bikes (dry clutches of course). A good semi-synthetic is all you need, even with hard usage. Or even a good quality mineral oil will probably suffice.
chaz
Re: Engine oil
« Reply #11 on: 16 July 2013, 09:57:12 pm »
car oil comes from oil that was laid down 165 million years ago from the decomposing bodys of 4 legged dinosaurs whereas motorcycle oil comes from dinosaurs that had only two legs and that's why it's more expensive?
Hedgetrimmer
Re: Engine oil
« Reply #12 on: 16 July 2013, 10:03:00 pm »
My guess is you've got young kids around Chaz? :lol
chaz
Re: Engine oil
« Reply #13 on: 16 July 2013, 10:09:22 pm »
no, just talking bollocks
Hedgetrimmer
Re: Engine oil
« Reply #14 on: 16 July 2013, 10:10:44 pm »
 :lol
Doddsie
Re: Engine oil
« Reply #15 on: 16 July 2013, 11:00:36 pm »
Soooo,we have sorted out the difference in car and bike oil, basically it all comes down to Diplodocus or Pterodactyl???    :eek
Next question..... is there any difference in Castrol and Duckhams etc or Asda`s own brand????
Hedgetrimmer
Re: Engine oil
« Reply #16 on: 16 July 2013, 11:13:56 pm »
This is a personal preference only but it's up to you - my bike is my pride and joy so I tend to use a good quality motorcycle specific oil, semi synthetic. Silkolene Comp 4 is my preferred choice (although there are others I'll accept - Motul, Shell, Castrol etc). Yes, it's pricey, but as oil changes are possibly the single most important thing you can do to help your bike's engine last, I feel it's worth it. And let's face it, the expense isn't that much every 4-6000 miles. A good mineral oil is probably not going to be any worse. I have an inherent distrust of supermarket brands, no reason for it, that's just me. Just been looking at the manual cam chain tensioner Devilsyam has been talking about. When I've got certain other things out of the way, I'll be going for one of those too - protect my pride and joy.
Doddsie
Re: Engine oil
« Reply #17 on: 16 July 2013, 11:18:01 pm »
A lot of people seem to distrust supermarket own brand stuff, but if its 10w40 semi synthetic bike oil, is it any different to the branded stuff??? Im guessing tesco dont have their own oil refinery so they are they not getting it from the same place?????
Hedgetrimmer
Re: Engine oil
« Reply #18 on: 16 July 2013, 11:31:42 pm »
I think it comes from the supermarkets f****ng up other things they've tried to get into in the past. You'd think they couldn't go far wrong with motor oil. As an example of why I don't use them, if you're going to buy an expensive camera and get serious about photography, you go to a camera specialist rather than a general store. And lets face it, your bike is not cheap -especially when things go wrong. I dunno, is that a good analogy? There again, with online shopping being so prevalent these days, maybe I'm just behind the times, but I'll still stick with what I know and trust at least until someone can completely convince me otherwise.
cfoley
Re: Engine oil
« Reply #19 on: 16 July 2013, 11:36:10 pm »
It may or may not make a mechanical difference but if you feel that way about the bike and can still afford rent and food then the branded oil sounds like it's worth it to you for peace of mind.
Hedgetrimmer
Re: Engine oil
« Reply #20 on: 16 July 2013, 11:44:08 pm »
Well, I'm not exactly loaded, but I'm in the fortunate position of being able to afford a couple of things like that at the moment. But I have been in the position of struggling for every penny more than once before, in fact have had to sell my bikes before due to lack of funds, so if you're on a tighter budget, I do understand. I think maybe look for the JASO MA2 approval as per Slaninars post in that case. Don't know where you could look to find out if these cheaper oils are really OK though.
chaz
Re: Engine oil
« Reply #21 on: 17 July 2013, 12:17:16 am »
I've been using GTX 10w40 semi synthetic in my car and bike if you go in wilko's, the shop not the motosave, every so often they reduce the price, recomended price is about £24 for 4 litres, normally it's £19.99 sometimes it's £14.99 and a bit ago it was £9.99
Slaninar
Re: Engine oil
« Reply #22 on: 17 July 2013, 05:32:53 am »
JASO MA, or better JASO MA2 motorcycle specific oil does NOT cause clutch to slip. That is false information.
Semi synth is good enough for most bikes (even though full synth is better in every way, except the price for most bikes).
Mineral oil is not worth the money, but each can choose for themselves.
I have already pointed out differences of regular car engine and a motorcycle one. So apart from marketing and lower production, there is some quality difference.
Look at the standards they comply with.  API SL and JASO MA2 oils tend to be more expensive than those complying to lower standards.
Also, some oils are branded "synthetic", but are really semi-synthetic.
Hedgetrimmer
Re: Engine oil
« Reply #23 on: 17 July 2013, 11:09:26 am »
Yes, just looked this up and it seems you are quite right Slaninar. Fully Synthetics don't cause clutch slip - my mistake, apologies. Do you perhaps know of a good site where we can read up on API and JASO standards?
Slaninar
Re: Engine oil
« Reply #24 on: 17 July 2013, 11:49:46 am »
Not in English I'm afraid.
This is more towards cars, and do not take it all for granted (as they claim to be "The Bible) of course:
