Date:
09-05-26
Time:
10:36 am
Home
Media
old - Fazer Owners Club - old
FZS600 Fazer
Mixture Screw Adjustment
« previous
next »
Print
Pages: [
Author
Topic: Mixture Screw Adjustment (Read 2637 times)
Kentish
Club Racer
on:
01 June 2013, 08:37:10 pm »
Hello All,
Do you adjust your settings by the manual ie 2.5 turns? My mate says his screws are all at different settings as the bike seems to sound better? I am nt sure about that. Shall I stick to what the manual says?
Logged
ade the blade
Club Racer
Re: Mixture Screw Adjustment
Reply #1 on:
01 June 2013, 09:02:06 pm »
2.5 turns normally is your starting point. you may have to fine tune them to get the response you require. with regards all at different settings etc, sound doesn`t even come into it. remember, all4 carbs are linked together and in an ideal world what one does the other 3 ideally follow. hence `carb syncing / balancing` so to sum up you are really aiming at having all 4 carbs as close as possible to their neighbour........carb #1 2 turns out, other 3 should be 2 turns out...........long winded, but hopefully helpful. oh with regards sound, the only way i know tpo alter that is to fart about with the end can in particular.....not carbs
hth. cheers Ade
Logged
Print
Pages: [
« previous
next »
FZS600 Fazer
SMF 2.0.19
SMF © 2011
Simple Machines
Simple Audio Video Embedder
Crushing Theme by
Diego Andrés
XHTML
RSS
WAP2
