Date: 09-05-26  Time: 10:37 am
Author Topic: Mixture Screw Adjustment  (Read 2638 times)
Kentish
« on: 01 June 2013, 08:37:10 pm »
Hello All,
                 Do you adjust your settings by the manual ie 2.5 turns? My mate says his screws are all at different settings as the bike seems to sound better? I am nt sure about that. Shall I stick to what the manual says?
ade the blade
Re: Mixture Screw Adjustment
« Reply #1 on: 01 June 2013, 09:02:06 pm »
2.5 turns normally is your starting point. you may have to fine tune them to get the response you require. with regards all at different settings etc, sound doesn`t even come into it. remember, all4 carbs are linked together and in an ideal world what one does the other 3 ideally follow. hence `carb syncing / balancing` so to sum up you are really aiming at having all 4 carbs as close as possible to their neighbour........carb #1 2 turns out, other 3 should be 2 turns out...........long winded, but hopefully helpful. oh with regards sound, the only way i know tpo alter that is to fart about with the end can in particular.....not carbs ;) hth. cheers Ade
