Date: 07-05-26  Time: 06:33 am
Author Topic: Sorry brake pads!!  (Read 11148 times)
Skippernick
Sorry brake pads!!
« on: 12 May 2013, 11:36:45 am »
Ok about to pull mine out and check them, might not have been inspected for 3 years gulp.
I've checked through the other topics and am now throughly confused.
My disc's are original so what are the best pads to get?? Whats the difference between sintered/organic? Are EBC/ Gulfer/ SBS a make? Race or road?
I don't ride hard or on track but would like to know that i have good anchors.
Please help in very simple language with perhaps a link to the pads you use.
Nick
kebab19
Re: Sorry brake pads!!
« Reply #1 on: 12 May 2013, 11:48:04 am »
Sintered pads usually offer better feel but at a cost, wearing the discs quicker. IMO they're still worth it tho.
Although there's plenty of other decent brands, the most popular pads for 600 (and 1000) owners appear to be EBC HH & SBS sintered (I've used SBS Street Excel - very nice). The others you mentioned may be better but are usually more £££
« Reply #2 on: 12 May 2013, 12:13:18 pm »
There are a lot of variables on this topic.
I have wavy aftermarket discs up front and my Galfer sintered pads are barely wearing at all, and are hardly scratching the surface of the discs either, it's a perfect scenario.
I've just tried SBS ceramics on the rear and after a couple of weeks of bedding in i'm very impressed by the pinpoint accuracy of braking when used in traffic, they are very responsive and bite well.
I would avoid sintered on the rear, as they are a bit harsh.
If you're interested in the Galfers they are much cheaper from Calsports site on Ebay, rather than their normal website.
I would be bold enough to say that this combination of pads is the best i've ever had in years of biking.  :)
Skippernick
« Reply #3 on: 12 May 2013, 12:27:03 pm »
Ok thanks guys.
Further more i have removed the rear pads, how do i know if they are worn, they are EBC FA104's theres no groove down the middle, theres about 5mm of raised material from the metal plate with what look like a plastic/paint layer covering the edge of raised material, is this all friction material or is this layer around the edge warning me it needs replacing.
Chris
« Reply #4 on: 12 May 2013, 12:30:57 pm »
I think If there isn't a groove down the middle then A) it's worn away or B) some pads have a notch out of one of the corners which is the marker instead of the groove.
Chris
Skippernick
« Reply #5 on: 12 May 2013, 12:32:28 pm »
Sorry modified above theres no notch either which is confusing me. :o
« Reply #6 on: 12 May 2013, 01:17:42 pm »
5mm is a lot of pad left!
You'll know when they're worn, they'll simply look knackered!
Skippernick
« Reply #7 on: 12 May 2013, 01:44:06 pm »
I know Darrsi, assuming that the 5mm is actual friction material.
I'm going to the steelers tomorrow to look at a new set and compare.
Its all very confusing and worrying, I have found out that they are organic pads, so something learnt.
Dead Eye
« Reply #8 on: 12 May 2013, 02:05:42 pm »
I have just ordered by new pads and have a set of EBC FA104's in their packaging - there is NO GROOVE on these pads down the middle so it isn't a sign that they are worn. 5mm of pad is loads of life left - my brand new ones are maybe 8mm thick? Basically, if there isn't any material left bar metal then you need to replace them, otherwise you are fine (unless your brakes feel off / bad / crap :P)
Going back to the original post quickly;
EBC, SBS, Galfer etc are manufacturers
- Sintered brakes have the best braking performance with minimal brake dust, but tend to chew up discs more than other types
- Ceramic pads trade off braking performance (more so when they are cold) for not destroying your discs and causes a little (minuscule amounts really) more brake dust than Sintered
- Organic pads are softer so chew your discs the least but don't have the sort of performance as the others. They also tend to produce a lot of brake dust but the braking is more progressive and less bitey / snatchy
So, I have Organic pads on the rear (I like the feel of them) and Ceramics up front
EBC FA104 for the rear - http://www.ebay.co.uk/itm/370751432977?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
SBS 634HF on the front - http://www.ebay.co.uk/itm/150791446789?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1439.l2649
Hopefully that helps :P
Skippernick
« Reply #9 on: 12 May 2013, 02:46:02 pm »
Oh thanks Dead Eye. Thats perfect, easily understood by the bear of little brain. :)
Thank you everyone for helping.
Next up, new brake lines, gulp, but that is another day when i get them. :lol
Dave48
« Reply #10 on: 13 May 2013, 09:02:03 am »
Skippernick,- Have just fitted Goodridge braided brake lines to my 03 FZS 600 as original rubber lines were 10 years old (Yamaha recommend changing hoses every 4 yrs)
I ordered a 2-line front (Race) set up: Goodridge ref no YA0613-2FC
and single line rear: -ref   no   YAO613-1RC
These are the correct replacements for Fazer FZS 600 98-03
They come with all banjo bolts & crush washers. ordered via M&P Direct(Swansea) ' cost inc P&P of  £82-18.
All fitted bled & tested Saturday in under 2hours ( including time to split clean check & reassemble rear caliper as pistons were "sticky" Job done-sorted! :lol
Skippernick
« Reply #11 on: 13 May 2013, 11:31:28 am »
Cheers Dave, if you live near Wiltshire you might be getting a call.
By the way pulled out the front pads and they are Sumitomo pads, i am assuming these are the original ones, so goes to show i and previous owner really are gentle on the brakes. Mind you i am of the philosophy of slow in fast out.
Dave48
« Reply #12 on: 13 May 2013, 02:02:46 pm »
I don't live nr Wiltshire am in S. Birmingham but would be willing to help as am retired with time to please myself! Incidentally I don't wear brakepads out as  the thou has stonking engine breaking which, if you are thinking well ahead, rules out the need for a lot of the braking to slow. Same with the 600-good standard fitment front brakes & adequate rear. Have decided to leave some of the service jobs til autumn/winter ie brake master cylinder overhaul kits, rear susp/pivot bearings, swingarm strip & grease. Ought to check valve clearances though as 34500 on odo. Slow in ...Fast out .... :eek love it! :lol
Punkstig
« Reply #13 on: 13 May 2013, 04:00:05 pm »
Ferodo platinums.
The best pads I've ever used and continue to use, and the only pads I've found just as good in the wet as the dry!
Skippernick
« Reply #14 on: 13 May 2013, 08:15:02 pm »
Yeah keep putting those off as well. :\
Weird Punkstig i've never noticed a loss of performance in mine wet or dry, but like dave says i use engine breaking and light on the breaks probably won't effect it that much.
Skippernick
« Reply #15 on: 13 May 2013, 08:18:17 pm »
And another thing was looking into piston seal sets for the brakes, front calipers are £45 off ebay, thought that was steep until my yamaha steeler quoted £125 for genuine yamaha ones gulp.
What is the Yamaha parts website called?
JZS 600
« Reply #16 on: 13 May 2013, 08:29:23 pm »
Yeah, I've got Ferodo Platinum's in on the front AND I did a track day at Brands Hatch, and I don't see much dust coming out of them whilst I'm doing 350 miles a week as well.
JZS 600
« Reply #17 on: 13 May 2013, 08:35:10 pm »
Also, tell you what, you try EBC sintered in the wet and tell me how that one goes!
risticuss
« Reply #18 on: 13 May 2013, 10:08:03 pm »
Re - Goodridge Braided lines £65.98 plus £6 postage for 2 lines
HEL braided lines £59.99 delivered. I had these on my CBR6 and they were fantastic, Will be upgrading on my 03 fazer soon. And you can have any colour of line, and any colour banjo fittings. Plus a rear too for only £30.00 more.
Just thought I'd let everyone know. (I don't work for HEL by the way, just like saving a few quid, and they aren't an inferior product.)
Simon
« Reply #19 on: 13 May 2013, 10:37:12 pm »
Got Venhill on mine(i think), sweet as a nut!
Dead Eye
« Reply #20 on: 14 May 2013, 01:42:51 am »
The main one I use is by AJ Sutton and is here http://www.yamahascooterspares.co.uk
I've just bought HEL lines as well - full setup (2 Front + 1 Rear) for £86.99 delivered - http://www.ebay.co.uk/itm/321070837376?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
Dave48
« Reply #21 on: 14 May 2013, 07:10:03 am »
Hel brake lines F&R = £89-99
Goodridge           "       £82-18    saving  £7-81!
Re brake piston seals. Have tried pattern parts, which can be "hit & miss" regards fit -however Yamaha really take the p**s with their prices. Cost me £85-03 just for the F & R master cylinder overhaul kits(Yamaha) & a further £32-47 for Nikone(pattern) seals from Cardiff M/Cs. Can understand Yamaha profiteering from accessories but for basic safety items its scandalous! :eek  So when I have to buy brake parts for the cage it seems like an absolute bargain!
risticuss
« Reply #22 on: 14 May 2013, 09:53:08 am »
Bugger, did the goodridge ones come with pu sleeving and stainless fittings as standard, as a mate of mine ordered them and had to pay more for the ends and sleeve. That's why I got to HEL ones as at the time, all were included.
Buzz
« Reply #23 on: 14 May 2013, 10:48:28 am »
risticuss - yes they come with pu sleeving and SS fittings if you choose those options..about £85 for F&R
You can get the Venhill F&R, sleeved and SS for £77 inc. del.
Dead Eye
« Reply #24 on: 14 May 2013, 11:11:56 am »
Call me stupid but how do you connect the 2 front lines to the master cylinder?
EDIT: - Looks like you either get a 3 line setup or use a double banjo bolt - good old search.
Yup, double banjo for 2 front lines
My HEL kit arrived this morning, YAY!! Going out to fit them :D :D :D
