Date: 29-03-26  Time: 03:35 am
Author Topic: outer race of front wheel bearing stuck in hub  (Read 1591 times)
Robfzs
« on: 24 April 2013, 03:26:53 pm »
tried everything, dremel slot, chisel/ punch, heat gun, hammering, got a little bit of it off, but by now if it was normal it should have peeled off, so it must be welded to the hub, any ideas to remove it ?
thanks
Re: outer race of front wheel bearing stuck in hub
« Reply #1 on: 24 April 2013, 05:57:16 pm »
Where did you apply the heat with the heat gun?
griff86
« Reply #2 on: 24 April 2013, 07:39:16 pm »
I used the dremel aluminium oxide grinding stone and cut away one part of the outer race which made it easy for it collapse into itself.
