Date:
29-03-26
Time:
03:35 am
Home
Media
old - Fazer Owners Club - old
FZS600 Fazer
outer race of front wheel bearing stuck in hub
« previous
next »
Print
Pages: [
Author
Topic: outer race of front wheel bearing stuck in hub (Read 1590 times)
Robfzs
DAS Born Again
on:
24 April 2013, 03:26:53 pm »
tried everything, dremel slot, chisel/ punch, heat gun, hammering, got a little bit of it off, but by now if it was normal it should have peeled off, so it must be welded to the hub, any ideas to remove it ?
thanks
Logged
Gnasher
Naughty Corner
GP Hero
Re: outer race of front wheel bearing stuck in hub
Reply #1 on:
24 April 2013, 05:57:16 pm »
Where did you apply the heat with the heat gun?
Logged
griff86
Club Racer
Reply #2 on:
24 April 2013, 07:39:16 pm »
I used the dremel aluminium oxide grinding stone and cut away one part of the outer race which made it easy for it collapse into itself.
Logged
Print
Pages: [
« previous
next »
FZS600 Fazer
SMF 2.0.19
SMF © 2011
Simple Machines
Simple Audio Video Embedder
Crushing Theme by
Diego Andrés
XHTML
RSS
WAP2
