Date: 03-05-26  Time: 12:44 pm
Author Topic: 12v socket and sat nav fitted but compact Air Horn Woes  (Read 8837 times)
Fizzy Pies
  • Guest
« on: 24 February 2013, 01:01:26 pm »
not much to say about it really,
realised the compact twin tone airhorn I've bought will be a nightmare to fit as its not so compact  :( . gonna wait till Alex fits his as he had bought the same one and seems a pro at fettling!
cool storey bro? :lol
Re: 12v socket and sat nav fitted
« Reply #1 on: 24 February 2013, 01:13:17 pm »
I stuck my air horn just back from where you've put that 12v socket, there's a bracket under there that i think i had to trim down a bit then bolted the horn to it.
There's a side view picture here:
http://foc-u.co.uk/index.php/topic,5660.0.html
simonm
« Reply #2 on: 24 February 2013, 01:49:18 pm »
I bought one of those satnav cases.  Are we fellow cheapskates ?
simonm
« Reply #3 on: 24 February 2013, 01:53:05 pm »
I was planning on doing exactly the same 12v socket install.  Now wondering if I should keep it under the seat and route the cable instead.  The idea of zip ties near my steering isn't something I'm too fond of.
Re: 12v socket and sat nav fitted but compact Air Horn Woes
« Reply #4 on: 25 February 2013, 01:19:40 pm »
Excuse the wires, i've got other stuff going on down there!  :rolleyes
So the open screw hole you can see is for the rear screw of the left infill fairing panel.
The open end of the horn is facing down to avoid any water issues.
« Reply #5 on: 25 February 2013, 06:27:32 pm »
It's mounted to an original bracket (the rusting bolt under the blue connectors), although i vaguely remember something being hacksawed off to make room? This was done years ago so i'd need too see another bike that hasn't been tampered with to see exactly what i've done?
The infill tray sits as normal.
« Reply #6 on: 26 February 2013, 11:22:47 am »
I'll be totally honest, electrics are definitely not my thing, i just wire things as i go along as per instructions, and as my air horn was fitted years ago that drawing doesn't mean too much to me!
But i'm sure some nice chap on here will point you in the right direction!
Having electronic engineers at work is a kind of bonus for me too  :)
Have a look at this  :thumbup :   http://www.google.co.uk/imgres?imgurl=http://www.nathanielsalzman.com/img/8_29_08/HornWiringDiagram.gif&imgrefurl=http://www.nathanielsalzman.com/diy/diy-stebel-nautilus-air-horn/&h=725&w=597&sz=14&tbnid=XYqV2OLuZ-dMWM:&tbnh=90&tbnw=74&prev=/search%3Fq%3Dwiring%2Bdiagram%2Btwin%2Bairhorn%26tbm%3Disch%26tbo%3Du&zoom=1&q=wiring+diagram+twin+airhorn&usg=__ZBIy1BhTi4LOEL5W79Qfs-HfWL8=&docid=kCyehzldqNGeJM&hl=en&sa=X&ei=OJ8sUfOsJ_So0AXTnYGADQ&sqi=2&ved=0CFcQ9QEwBA&dur=3921
Exupnut
« Reply #7 on: 26 February 2013, 11:43:07 am »
Try this fizz it may help.
http://www.bikerhiway.com/images/large/amanet/snpnp_01_LRG.jpg
Sent from my iPhone using Tapatalk 2
Ebme Geek
« Reply #8 on: 26 February 2013, 12:04:38 pm »
Yes your diagram would work, but go with Darrsi or Exupnut, which ever you find clearest, Darrsi's doesn't show the fuse but are otherwise they're the same. That way the horn will only work when the ignition is on.  :)
Ebme Geek
« Reply #9 on: 26 February 2013, 01:36:52 pm »
Looks spot on to me   :)
alexanderfitu
« Reply #10 on: 01 March 2013, 12:33:44 pm »
going off my last diagram then, could the - on the horn go to the - on the battery?
It could, but would be easier to wire the ground through the bolt that the horn will mount onto.  :D
alexanderfitu
« Reply #11 on: 01 March 2013, 10:01:38 pm »
Happy days! :)
« Reply #12 on: 01 March 2013, 10:46:50 pm »
Too late I went - off the battery :).
Well its fitted, just. I was  :'( hacksawing off the old mount from the frame, still a bit  :( now.
But its wired up too, and it works, and its really loud!
So its  :D in the end!
Told ya there was a bit i hacksawed off!!
bozboz
« Reply #13 on: 02 March 2013, 10:02:41 am »
Well done fizzy! :) -that was a headache in the chat room the other night!
