Date: 03-05-26  Time: 23:20 pm
Author Topic: Swapping the exhaust how to??  (Read 17232 times)
xlewisbdx
« on: 05 February 2013, 11:23:20 pm »
Does anybody know how to change the exhaust? What process is required etc etc.
I am about to buy a end can for the bike (DanMoto) and wanted to know how I would change it.
Re: Swapping the exhaust how to??
« Reply #1 on: 05 February 2013, 11:39:00 pm »
For starters, make sure your link pipe is the same diameter hole as the new end can and the downpipes, they're not all the same, as i found out when fitting mine!
If it's the same then it's just a jubilee clip to undo and a hanging bolt, hence the term "slip on".
Some people use a high temp silicone sealant to seal the join, i would personally avoid Gun Gum though as it's horribly messy to use and dries solid, so if you want to take it off later on you need to chip it all off.
Chris
« Reply #2 on: 05 February 2013, 11:46:46 pm »
There is a jubilee clip to undo just at the end of the link pip where it joins the downpipes (just behind the right riders foot pegs) then there is the hanger to remove from the rear pillion footrest, then it's a "simpl"e case of pull it off the downpipes and "slip on" the new one onto the downpipes and do up the jubilee clip to clamp the seal so it doesn't leak.
packie
« Reply #3 on: 05 February 2013, 11:51:34 pm »
Download the Haynes Manual in the download section. Go to chapter 4 and section 13. It gives you the procedure with photos. Self explanatory.
« Reply #4 on: 05 February 2013, 11:54:51 pm »
"Should" be that simple, a lot of people buy downpipes before the end can, but my aftermarket downpipes are a different diameter to originals (plus i don't know what make they are either for reference?).
And seeing most end cans are measured and advertised to fit original downpipes then you can have a problem like i did where the link pipe was about 5mm difference in size!
That's when a bit of improvisation kicks in!
xlewisbdx
« Reply #5 on: 05 February 2013, 11:57:31 pm »
Thanks for the advice guys.
What comes with the exhaust is:
link pipe
hanging strap
bolt with lock nut
Does anybody know about the legalities of it?
Chris
« Reply #6 on: 06 February 2013, 12:02:39 am »
It's all about problem solving when you come up against things like that and usually it's the simple solution that's the best. have a look at the haynes manual and you'll be fine. only way to learn is to get stuck into it. there's always a solution to any problem... sometimes they can be expensive solutions but we all learn from experience and most experience comes from having to solve a problem or two.  :D
as for the legalities. it'll say if it's road legal or not somewhere on the advert. My blueflame exhaust comes with a removable baffle. If I leave it in then it's legal and if the baffle is out then it's illegal. simple  ;)  We all know which sounds the best but we also know that it's not strictly legal. having said that we are bikers and legal isn't always the side we stand on  :eek
xlewisbdx
« Reply #7 on: 06 February 2013, 12:04:44 am »
Except for when the MOT comes round ;)
Chris
« Reply #8 on: 06 February 2013, 12:08:29 am »
As far as exhaust go then yes, the MOT can be the killer so Baffles are in for that for sure  :)
Although, the eu stamp is on the actual exhaust and not the baffle so you could argue the point that it's got the stamp so it's ok. This is not a good idea and the best thing to do is to keep the baffle in. So I do... most of the time. haha
« Reply #9 on: 06 February 2013, 12:08:38 am »
That's another issue altogether, depends on your examiner?
Some want to see BSAU markings or the original exhaust, others don't give a monkeys!
The police like to see a baffle in place, it's an easy thing to spot for them.
Chris
« Reply #10 on: 06 February 2013, 12:14:41 am »
Some police are fine and others aren't. Best to be on the safe side  :)
xlewisbdx
« Reply #11 on: 06 February 2013, 12:15:22 am »
Most of the time being the one day a year it's needed  :lol
xlewisbdx
« Reply #12 on: 06 February 2013, 12:17:19 am »
I have a Delkevic 350mm at the moment without the baffle in. I've not been pulled over yet  ;)
« Reply #13 on: 06 February 2013, 12:17:26 am »
My last exhaust was a Quill straight through race can, no markings and didn't have a baffle fitted at all, and used to fly through MOT's.
The SP Engineering can i have now has BSAU markings, a baffle, and at the first MOT i got an advisory for noise!!
I then pointed out the legal markings but he'd printed the MOT already so i had a year with an advisory notice on which the police could see on their system if they did an ANPR check on the bike!
« Reply #14 on: 06 February 2013, 12:18:37 am »
Famous last words.........
Chris
« Reply #15 on: 06 February 2013, 12:21:37 am »
that'll be a ticket tomorrow then! hahaha.
My excuse to my MOT guy was that it's a sports bike it's supposed to be loud, and even with the baffle in the blueflame is wicked, he agreed and through it sailed... Back brake got an advisory though!!! cleaned out, new hel brake line and new fluid, so we'll see how it goes throught the next one!
xlewisbdx
« Reply #16 on: 06 February 2013, 12:37:52 am »
More than likely, especially if I have a DanMoto on...
Chris
« Reply #17 on: 06 February 2013, 12:40:15 am »
Hmm, friend of mine had a dan moto on his hornet.. wasn't that much louder than stock to be honest...
xlewisbdx
« Reply #18 on: 06 February 2013, 12:44:04 am »
really? They sound super loud on videos. To be honest I want an under tray before a exhaust.
Chris
« Reply #19 on: 06 February 2013, 12:51:57 am »
Video's can be decieving  ;)
What other mods has your bike got?
xlewisbdx
« Reply #20 on: 06 February 2013, 12:55:21 am »
Off the top of my head.;
Double Bubble
heated grips
blue lights in the clocks
rear hugger (came with the bike when I bought it)
Delkevic 350mm Stubby (came with the bike when I bought it)
14t front sprocket
You?
Edit: thats a lot of mods now I think about it...
Chris
« Reply #21 on: 06 February 2013, 01:05:37 am »
Black double bubble
clear indicator lenses (probably my favourite mod as it brightened up the whole bike)
had a carbon rear hugger when i got it,
blueflame end can,
k&n air and oil filter,
came with a belly pan on it,
I did the blue led in the dial mod the other day, love them, always hated the greeny yellow lights that were in it,
just had my wheels powder coated black.
Think that's about it. I have a pic or two in my introduction thread "hello from up north" check it out, it's before i put the blueflame on it though.
xlewisbdx
« Reply #22 on: 06 February 2013, 01:10:09 am »
Nice.
I want a K&N Air filter but I am restricted to 33bhp so it will increase thus making me illegal. (again) :P
Chris
« Reply #23 on: 06 February 2013, 01:13:50 am »
Ah i see, when does your liscence become unrestricted?? I waited till I could do the direct access and then did my test. Promised my dad I wouldn't get a bike till I was over 21 and had been driving a car for a few years first so I knew the rules of the road and had some experience of how traffic behaves etc.
Dead Eye
« Reply #24 on: 06 February 2013, 01:36:23 am »
If you have a Delkevic end can already, why switch to the Dan Moto? Admittedly I have no experience with either of these brands but I'm not sure I can see the justification.
Also, just to throw it out there, I have a Beowulf Warrior 380mm can which has BSAU markings with a removable baffle. The baffle was in twice over the 9 month period that I was using it :P And it won't be in when I refit it to my new bike. I've never actually been pulled over by the policy, be it in my cars or on my bike :)
