Date: 08-05-26  Time: 18:38 pm
Author Topic: pressure plate problem  (Read 5523 times)
bm
« on: 25 October 2012, 03:28:27 pm »
fazer 600 t reg
started the bike up ok,
selected 1st gear
bike conked out,
thought it was the clutch stuck together,
took clutch out,
cleaned and oiled plates,
but found the pressure plate at the rear had bits missing where the springs touch.
any ideas why this would happen?
where can i get a replacement pressure plate?
Re: pressure plate problem
« Reply #1 on: 25 October 2012, 04:06:10 pm »
I've no idea about your biking experience so forgive me if i'm way off but did you put it into gear with the side stand down?
And i don't understand why you'd oil clutch plates?
bm
« Reply #2 on: 25 October 2012, 04:13:58 pm »
side stand was up when put into gear,
clutch plates are oiled otherwise they stick to eachother
« Reply #3 on: 25 October 2012, 04:34:46 pm »
Okay, as you can probably tell i've never had to change a clutch before so i've learnt something new today!
bm
« Reply #4 on: 25 October 2012, 04:41:14 pm »
think i have found the problem , its similar to thundercat engines,
the presure plate can only fit one way into the basket,
and take off the sprocket cover to stop the push rod from putting pressure on the clutch plates,
so all i need to do is find a replacement plate,
then will take photos and show here
bm
« Reply #6 on: 25 October 2012, 05:00:02 pm »
£45 for it :eek
think i could buy a complete clutch unit for that,
searching continues
« Reply #7 on: 25 October 2012, 05:04:10 pm »
Yeah, new parts are never cheap unfortunately!!  :rolleyes
You could try a breakers search online, but it may be one of those parts that won't be sold seperately?
His Dudeness
« Reply #8 on: 25 October 2012, 06:10:59 pm »
maybe someone has put stiffer springs in it. can you describe the damage a bit better?
Skippernick
« Reply #9 on: 25 October 2012, 06:44:40 pm »
Its a wet clutch so it would be oiled when fired up?
« Reply #10 on: 25 October 2012, 08:49:35 pm »
@Skippernick, that's why i asked the question, but after a bit of research you're supposed to soak clutch plates in oil before fitting, preferably over night if possible!
You live and learn......... :)
Skippernick
« Reply #11 on: 25 October 2012, 10:38:38 pm »
Ah i see. Was that on that you tube video that was kicking around here a while back about replacing fazer clutches i wonder?
« Reply #12 on: 25 October 2012, 11:07:32 pm »
No, i know the one you mean, but i've seen it mentioned in a few other places too.
I've never had to change a clutch so it's it's not something i've really looked in to, to be honest.
« Reply #13 on: 25 October 2012, 11:27:10 pm »
Any chance you could post a picture of the part in question?
« Reply #14 on: 26 October 2012, 06:48:51 am »
Look at the link i posted above and it's #7
bm, deefer666 who posts on here has a Fazer breakers yard, you could try him on 07887 854 614
« Reply #15 on: 26 October 2012, 08:17:01 pm »
I was asking about a picture of the damaged part that you have. Much easier to comment on a picture as it answers a thousands questions.
Refitting new plates is very easy on the fazer and you don't even have to drain the oil if you leave it on the sidestand. However the torque on the pressure plate bolts is very low 8Nm (5lbs) and easily stripped. Which is why I have always recommended beginner mechanics buy or borrow a torque spanner in the 0 to 20 Nm range, they may be close to £100 but will save a fortune in the future.
Replace the springs at the same time with OEM ones.
Soak the plates in engine oil over night if possible, wipe off all the excess oil before fitting and fit them in reverse order of removal.
Friction plate, steel plate, damper ring and its friction plate, steel plate and so on.
The pressure plate should sit flush and may need to be rotated to get it to fit correctly.
As long as you have not removed anything else, then a new gasket and chek the dowels are in place and replace the cover, tighten the cover bolts in a criss cross patern to 12Nm.
Check the free play at the clutch lever and the oil level (just to be sure) i and fire it up.
