Date: 20-03-26  Time: 18:30 pm
Author Topic: error code question Help please  (Read 2968 times)
dx408
« on: 05 October 2012, 02:54:11 pm »
Hi just had my bike back after selector forks being changed (Still jumping out of 2nd so must go back) but had an error code on rev counter:-
Engine revs - 0 - 4000 - 0 - engine revs
anyone know what this one means ????
Re: error code question Help please
« Reply #1 on: 05 October 2012, 04:18:37 pm »
dx408
« Reply #2 on: 05 October 2012, 08:28:30 pm »
Thanks
MEM62
« Reply #3 on: 09 October 2012, 08:13:41 pm »
According to my manual, this is the error code for a speed sensor fault.
Gingernutz
« Reply #4 on: 09 October 2012, 09:25:28 pm »
Yup ceramic drive dog in the speedo is probably broken (assuming fzs600) taking off the front wheel or putting it back on can break it. Mine cost about £15 to replace but yamaha have to order it for you
« Reply #5 on: 10 October 2012, 06:52:14 am »
If it's the lugs that are broken, the speedo just won't work, i don't think that it would give out an error code because it just wouldn't do anything, it'll just sit at 0mph!
An error code would suggest a wiring/speed sensor fault.
« Reply #6 on: 10 October 2012, 09:41:27 am »
Darrsi - It's not the speedo that gives out the error code, its the TPS which monitors the connections and displays the error via the rev counter
This is direct from the manual as I had this issue, the most common cause is broken lugs as most have already suggested, especially if you've just had the wheel off.
Replacement part for the lugs can be ordered from here (Part 13-1); http://www.yamahamotorcyclespares.co.uk/spares/epc2.asp?modelID=9654&PageiD=41&m=YAMAHA+FZS600+Fazer+METER&uID=0
Granted its worth shopping around and checking Fowlers but at least it helps to know what you are after
« Reply #7 on: 10 October 2012, 10:41:35 am »
That's what i was trying to say, broken lugs would not give an error code, the speedo just wouldn't register anything, as if the bike isn't moving!
