Date: 04-05-26  Time: 13:44 pm
Author Topic: TPS  (Read 3962 times)
bigsteve
TPS
« on: 20 September 2012, 10:48:02 pm »
Hi
  Ive just stripped carbs and cleaned jets due to a blocked pilot jet  after refitting carbs checked they were balanced then checked TPS and its showing 3000 on rev counter
 I cant adjust it at the moment due not having security torx typical
 technical question ????  what effect does the TPS have on the engine ??
CRH
Re: TPS
« Reply #1 on: 20 September 2012, 10:54:41 pm »
the tps is throttle position sensor, and provides info to the ignition control unit ..on throttle opening and closing positions!!! ;)
bigsteve
Re: TPS
« Reply #2 on: 20 September 2012, 10:56:42 pm »
  thanks
   in want way would it reading 3000 effect running ??????
CRH
Re: TPS
« Reply #3 on: 20 September 2012, 11:04:26 pm »
not quite sure steve on that?..but it should read 5000,if it shows 0,or 10,000 it needs adjusting!!...i think the 3000 reading says theres a fault and it needs adjustment if i remember rightly as i had same prob on me fjr?,its easy though to fk up your settings just by tightening the screws up so ...bit at a time mate? ;)
Re: TPS
« Reply #4 on: 21 September 2012, 12:56:11 am »
3000 rpm is the TPS, it is either disconnected or short circuited. Check all the connections and cable.
The timing is set to a fully opened throttle, it is a get you home mode
thom_1991
Re: TPS
« Reply #5 on: 07 October 2012, 04:56:31 pm »
Does anybody know exactly what size Torx bit it is. Balanced my carbs and decided to check the TPS and predictably it need adjusting. Cheers.
John Silva
Re: TPS
« Reply #6 on: 07 October 2012, 05:55:36 pm »
T25 if I remember rightly
thom_1991
Re: TPS
« Reply #7 on: 08 October 2012, 08:49:48 am »
Ah cheers, ordered a set of T5-T40.
John Silva
Re: TPS
« Reply #8 on: 08 October 2012, 10:21:47 am »
Dont forget its the SECURITY torx bit you want with the hollow centre not the normal bit which is solid.
Sorry if you already know I'm just making sure you get the right jobby.
thom_1991
Re: TPS
« Reply #9 on: 08 October 2012, 06:19:17 pm »
Oops. Ah well, least I'm well stocked now... :)
thom_1991
Re: TPS
« Reply #10 on: 10 October 2012, 06:16:10 pm »
Adjusted the TPS in about 10 seconds in my lunch break and was rewarded with a bike that starts more eagerly and revs far more crisply from idle. Worth the £3 outlay for correct Torx bit if it needs adjusting imo.
John Silva
Re: TPS
« Reply #11 on: 11 October 2012, 09:55:24 am »
 :D Another happy Foccer
