Date: 09-05-26  Time: 22:21 pm
Author Topic: fazer fzs 600 1999  (Read 12853 times)
gordon
fazer fzs 600 1999
« on: 18 June 2012, 10:39:37 am »
hi guys i have a fazer fzs600 as my first bike and i,m well happy with it ,but is it right that at 60mph it should rev at 6000rpm ?.as far as i know its standed gearing
Panthor
Re: fazer fzs 600 1999
« Reply #1 on: 18 June 2012, 11:38:48 am »
off the top of my head i think mines around 5k. If no one else knows for sure ill check when im out for a spin at lunch time. :D
gordon
« Reply #2 on: 18 June 2012, 11:56:46 am »
cheers pal,since i posted that someone said how many miles u get 210 from right full to when light comes on.
Panthor
« Reply #3 on: 18 June 2012, 12:04:14 pm »
i get around 200 but mine will be different to yours as mine is the later one with a slightly bigger tank and i also do a lot of short journeys and getting around 48-50 mpg, which seems a bit low as most get mid to high 50's on here.
gordon
« Reply #4 on: 18 June 2012, 12:49:51 pm »
18 ltrs mine holds its off 2002 model as mine had a leak init ,put 9 ltrs in on a sunday went away for the week ( lorry driver ) came home and no fuel
spider
« Reply #5 on: 18 June 2012, 12:54:57 pm »
oh god i must cane mine. 1999 fazer. 165 mpg if i am lucky. a roads and b roads
spider
« Reply #6 on: 18 June 2012, 12:56:29 pm »
60mph is just below 5,000 revs thats  approx. are you in 6th gear
« Reply #7 on: 18 June 2012, 01:24:53 pm »
If it's a later tank it should be 20 litres in total, including 3.5 litre reserve, the older ones are 18 litres.
I try not to let my tank go under a third full at any time though, and i wouldn't have a clue about mileage.
I think cruising revs should be around the 4500-5000rpm from memory(i could be wrong?), although they do have a highly strung engine that doesn't mind being revved, hence the reason it redlines so high.
Panthor
« Reply #8 on: 18 June 2012, 01:39:31 pm »
In 6th mine is just below 5k at 60
Skippernick
« Reply #9 on: 18 June 2012, 02:02:40 pm »
 :agree
Dead Eye
« Reply #10 on: 18 June 2012, 02:22:42 pm »
Agree with above - mine is also pretty much bang on 5k for 60mph in 6th gear and about 5.9k for 70mph
As for tank range, I get about 180 miles for 15 litres based on my fillups via Fuelly.
Strifae
« Reply #11 on: 18 June 2012, 02:27:24 pm »
On my old FZS600 6K was 70mph - aroudn 5k for 60
sounds like gearing has been messed with
« Reply #12 on: 18 June 2012, 05:27:41 pm »
You weren't pulling a trailer behind it were you?  :lol :lol :lol
« Reply #13 on: 18 June 2012, 09:06:07 pm »
5000 at 60.........were you in 5th  :rollin :rollin :rollin
Fazer Jake
« Reply #14 on: 18 June 2012, 09:59:19 pm »
Probs someones messed around with the sprockets for more acelleration
limax2
« Reply #15 on: 18 June 2012, 11:17:08 pm »
Standard gearing is 15 teeth front sprocket and 48 rear. As others have said yours isn't standard or your not in 6th gear. That's assuming your clutch isn't slipping  :eek , but I guess if it was it would have burned out by now.
I'm a bit of a nerd when it comes to fuel consumption and always record how much I'm putting in. Driven sensibly and without much town work I consistently get 58 to 60 m.p.g.. Plenty others get the same. On my 2001 model this gives a range of at least 200 miles before the fuel low light starts to come on. Some others, who probably thrash about more than me, seem to get round the 50 m.p.g. mark.
AdieR
« Reply #16 on: 19 June 2012, 12:53:25 am »
If it helps, my FZ6 (which followed on from the FZS) runs 5k rpm at 60mph (standard sprockets on that are 16T front 46T back).
« Reply #17 on: 19 June 2012, 01:12:10 am »
As people have said, start by counting the teeth on the sprockets (15f & 48r), it's only a few bolts on the sprocket cover, and make sure they're standard, and check the sprocket nut for any nastiness while you're at it.
gordon
« Reply #18 on: 20 June 2012, 10:26:26 pm »
thanks lads first off i,m in 6th , as for teehth not counted them yet  8) by gum its shifts though the most i,v had out of it is 115 ish before i chickened out
« Reply #19 on: 21 June 2012, 12:57:01 am »
Had 135 with a passenger on board, but a blasted car decided to change lanes about a quarter of a mile ahead of me so had to shut down, but there was more throttle for the taking!  :lol
Still don't know it's full potential, but i'll let you know when it happens, or read about me in the newspapers?  :D
Ben600
« Reply #20 on: 21 June 2012, 12:58:51 am »
This has helped me in the past with gearing conundrums... Hope it helps :)
http://www.gearingcommander.com/ Just whack in the make model and year of the bike, choose mph or kmh and away you go
P.s. mine will do an indicated 150, which on the dyno translated to 144.8 mph
ade the blade
« Reply #21 on: 21 June 2012, 06:58:53 pm »
has anybody noticed the obvious question (s) not asked as yet ? like are you a ballet dancer or a 5 ton porker ? are you 2 foot 8 inch tall or a team player for the harlem globetrotters? all effects the power to weight theories / drag.also the obvious rev difference when idle and `under load`.
« Reply #22 on: 21 June 2012, 09:30:18 pm »
I would laugh hard if he said he was 6' 8" and 37 stone  :rollin :rollin :rollin
No offence Gordon  :lol
ade the blade
« Reply #23 on: 21 June 2012, 09:40:27 pm »
if that was true, then picture the scene.......it wouldn`t be a fazer he`s sat on............more like a bloody puch maxi :lol :lol :lol :lol
blue_faz600
fazer fzs 600 1999
« Reply #24 on: 04 July 2012, 03:22:36 am »
I agree with you Ade, but surely a drop of nearly 1k in RPM  points to gearing being molested? My bike has std gearing and sits bang on 6k @ 70mph. I'm 5'1" and 85kgs BTW! ;)
