Date: 09-05-26  Time: 19:40 pm
Author Topic: FZ1 and FZS wheel bearings & Seals:  (Read 11274 times)
« on: 04 January 2021, 09:23:17 pm »
So as I needed some wheels bearing for the FZ1 I thought I would check if any of the spare bearings I still have for my FZS would fit, and some of them do -
Front wheel: (FZS part numbers same)
  • 2x bearing (ball)- 93306-00420
  • 2x seal - 93106-28043
Sprocket carrier: (FZS part numbers same)
  • 1x bearing (ball)- 93306-20531
  • 1x seal - 93106-40013
Rear Wheel (FZ1):
  • 1x R/H bearing (ball) - 93306-20531 - bearing number 62-28-2-RS
  • 1x R/H seal - 93106-40013 - seal number 40-58-7
  • 1x L/H bearing (roller) - 93317-33590 -  bearing number 35-20-2-RS
Rear Wheel (FZS):
  • 1x R/H bearing (ball) - FZS - 93306-07806 - bearing number 62-28-2-RS (so same as FZ1)
  • 1x R/H seal - 93106-35042 - seal number 35-52-8
  • 1x L/H bearing (roller) - 93317-43580 - bearing number  35-20-2 RS (so same as FZ1)
So the only part that different between both bikes is the R/H (exhaust side) seal, so this means the R/H wheel spacer has different ID/OD between the two bike's.
I personally prefer to source all my bearings/seals from Marksman Industrial, as you can put in the Yamaha (or Suzuki, Honda etc) and it will find your bearing/seal for you. They also have 'bearing kits' for both bikes, which can save you a chunk of change compared to going oem or even wemoto -
kralik
Re: FZ1 and FZS wheels bearings:
« Reply #1 on: 07 January 2021, 09:56:10 am »
thanks a lot for this information.  :)
« Reply #2 on: 07 January 2021, 01:17:27 pm »
Your welcome. I did this because I had some bearings and seals sitting in my cupboard for my previous FZS, so I needed to know what parts were shared between the two bikes if any.
