Date:
09-05-26
Time:
18:35 pm
Home
Media
old - Fazer Owners Club - old
Fazer 1000/FZ1 corner
FZ1 and FZS wheel bearings & Seals:
« previous
next »
Print
Pages: [
Author
Topic: FZ1 and FZS wheel bearings & Seals: (Read 11272 times)
b1k3rdude
Administrator
GP Hero
on:
04 January 2021, 09:23:17 pm »
So as I needed some wheels bearing for the FZ1 I thought I would check if any of the spare bearings I still have for my FZS would fit, and some of them do -
FZ1 - fowlers -
https://www.fowlersparts.co.uk/parts/6391774/fz1-sa-fazer-5d01-2007-050-c/rear-wheel
FZS - fowlers -
https://www.fowlersparts.co.uk/parts/4189081/fzs1000-1c28-2005-050-a/rear-wheel
Front wheel:
(FZS part numbers same)
2x bearing (ball)- 93306-00420
2x seal - 93106-28043
Sprocket carrier:
1x bearing (ball)- 93306-20531
1x seal - 93106-40013
Rear Wheel (FZ1):
1x R/H bearing (ball) - 93306-20531 - bearing number 62-28-2-RS
1x R/H seal - 93106-40013 - seal number 40-58-7
1x L/H bearing (roller) - 93317-33590 - bearing number 35-20-2-RS
Rear Wheel (FZS):
1x R/H bearing (ball) - FZS - 93306-07806 - bearing number 62-28-2-RS (so same as FZ1)
1x R/H seal - 93106-35042 - seal number 35-52-8
1x L/H bearing (roller) - 93317-43580 - bearing number 35-20-2 RS (so same as FZ1)
So the only part that different between both bikes is the R/H (exhaust side) seal, so this means the R/H wheel spacer has different ID/OD between the two bike's.
I personally prefer to source all my bearings/seals from
Marksman Industrial
, as you can put in the Yamaha (or Suzuki, Honda etc) and it will find your bearing/seal for you. They also have 'bearing kits' for both bikes, which can save you a chunk of change compared to going oem or even wemoto -
https://shop.marksman-ind.com/index.asp?function=SEARCH
Logged
kralik
Naughty Corner
DAS Born Again
Re: FZ1 and FZS wheels bearings:
Reply #1 on:
07 January 2021, 09:56:10 am »
thanks a lot for this information.
Logged
b1k3rdude
Administrator
GP Hero
Reply #2 on:
07 January 2021, 01:17:27 pm »
Your welcome. I did this because I had some bearings and seals sitting in my cupboard for my previous FZS, so I needed to know what parts were shared between the two bikes if any.
Logged
Print
Pages: [
« previous
next »
SMF 2.0.19
SMF © 2011
Simple Machines
Simple Audio Video Embedder
Crushing Theme by
Diego Andrés
XHTML
RSS
WAP2
