Date:
20-03-26
Time:
21:41 pm
Home
Media
old - Fazer Owners Club - old
Fazer 1000/FZ1 corner
How to check a fuel pump relay
« previous
next »
Print
Pages: [
Author
Topic: How to check a fuel pump relay (Read 1847 times)
Budthewiser
Cager in Training
on:
29 August 2020, 01:28:42 pm »
That's if lads, anyone know how to test a fuel pump relay. My bike will turn over bug will not start. I dont here the pump priming on start up.
Logged
Budthewiser
Cager in Training
Re: How to check a fuel pump relay
Reply #1 on:
31 August 2020, 10:37:40 am »
Any one???
So what happens is, when the bike it turned on the fuel pump is supposed to prime but its dead. I’ve checked to see if there is voltage to the pump and its seems to be intermittent. So before i buy a new one , is ther a test i can do to check the feul pump relay??
Logged
albuquerqueturkey
DAS Born Again
Reply #2 on:
01 September 2020, 03:25:21 pm »
Have you checked the earths? Mine came with an second earth soldered in so there must have been a problem with it at some point
Logged
Budthewiser
Cager in Training
Reply #3 on:
02 September 2020, 02:40:59 pm »
[size=78%]I put a multimeter on the connectors supply to the pump and got 12volts. I then took the fuel pump out and the connectors in the tank were badly corroded. The pump work fine so I've ordered a new fuel filter and while I'm waiting I'll double check the pump is pumping but I think I've solved the problem[/size]
[/size][size=78%]. All down to corroded connectors on the power supply to the pump[/size]
Logged
Print
Pages: [
« previous
next »
SMF 2.0.19
SMF © 2011
Simple Machines
Simple Audio Video Embedder
Crushing Theme by
Diego Andrés
XHTML
RSS
WAP2
