Date: 06-05-26  Time: 14:16 pm
Author Topic: How to check a fuel pump relay  (Read 2094 times)
Budthewiser
« on: 29 August 2020, 01:28:42 pm »
That's if lads, anyone know how to test a fuel pump relay. My bike will turn over bug will not start. I dont here the pump priming on start up.
Budthewiser
Re: How to check a fuel pump relay
« Reply #1 on: 31 August 2020, 10:37:40 am »
Any one??? :'( So what happens is, when the bike it turned on the fuel pump is supposed to prime but its dead. I’ve checked to see if there is voltage to the pump and its seems to be intermittent. So before i buy a new one , is ther a test i can do to check the feul pump relay??
albuquerqueturkey
« Reply #2 on: 01 September 2020, 03:25:21 pm »
Have you checked the earths? Mine came with an second earth soldered in so there must have been a problem with it at some point
Budthewiser
« Reply #3 on: 02 September 2020, 02:40:59 pm »
[size=78%]I put a multimeter on the connectors supply to the pump and got 12volts. I then took the fuel pump out and the connectors in the tank were  badly corroded. The pump work fine so I've ordered a  new fuel filter and while I'm waiting I'll double check the pump is pumping but I think I've solved the problem[/size] :lol [/size][size=78%]. All down to corroded  connectors on the power supply to the pump[/size]
