Date: 06-05-26  Time: 23:05 pm
Author Topic: Spot light mounting position  (Read 11291 times)
« on: 26 August 2020, 06:14:09 pm »
Hello Foccers,  during the recent hot weather I've taken to riding the twisties at night when it's cooler.
I want to fit some spot lamps to the front of the bike to help illuminate the lanes a bit better.
So, anyone fitted them ? Where abouts and how did you wire them ?
I'm thinking to splice them into the high beam as I don't want to think about pressing a separate switch when I'm on the move.
Bike is an FZS1000 also going the same route with the MT10.
Any ideas or advice would be helpful.  :)
Timbo
Re: Spot light mounting position
« Reply #1 on: 26 August 2020, 06:56:07 pm »
Please point them down you so don't blind me when I coming the other way!
« Reply #2 on: 26 August 2020, 07:55:56 pm »
How about I just turn them off like I would with my high beam  :think
b1k3rdude
« Reply #3 on: 26 August 2020, 09:19:14 pm »
I have fitted various spots and lighting upgrades to a fair few of my bikes, but here are some pics of my 2005 FZS1000 that had both LED spots and LED bulbs in the main lights and a video in a dark underground car park in London. Also also my old GSF1200 that had LED spots and HID dip beam.
« Reply #4 on: 26 August 2020, 10:05:37 pm »
So where did you mount them on the FZS ?  Looks like the mudguard fixings.
Timbo
« Reply #5 on: 27 August 2020, 09:22:11 am »
Good answer! ... I was a jessing a bit .... but there are a lot out there with lights that are badly set and blinding!
Personally I actually think less is more at night and let your night vision look into the periphery of you beam. After 40yrs of riding I still don't feel the need to fit them to either of my bikes but each to their own.
Bw
b1k3rdude
« Reply #6 on: 27 August 2020, 09:28:37 am »
No, I mounted them to the brake hose clamp lugs, with a spacer and a nylock nut on the backside.
robbo
« Reply #7 on: 27 August 2020, 09:42:16 am »
Hi Dazza,
Saw this Fazer at The Haven bike night a few weeks back. Spots mounted on the frame down tubes.
Trebus
« Reply #8 on: 27 August 2020, 09:56:56 am »
I’ve seen some mounted on the radiator but I’d worry that it would cause damage if dropped. The other concern is having them too close to the indicators which might over power them and not be seen well enough.
WayneUK
« Reply #9 on: 27 August 2020, 10:21:03 am »
Hi, how are the lights fixed is there a bracket on the lights?
b1k3rdude
« Reply #10 on: 27 August 2020, 02:43:48 pm »
I just mounted the spotlight with the braket it came with to the fork with a M6 bolt, spacer and nylock nut. The potlights were from -
- https://www.bikevis.com/product/bikevis-cree-motorcycle-auxiliary-lights/
WayneUK
« Reply #11 on: 28 August 2020, 10:55:48 am »
How did you wire them up?
b1k3rdude
« Reply #12 on: 28 August 2020, 02:50:51 pm »
Straight into the sidelight circuit, so I was able to turn them off for the MOT.
WayneUK
« Reply #13 on: 30 August 2020, 03:57:49 pm »
Where bouts did you join them to the sidelight circuit?
b1k3rdude
« Reply #14 on: 30 August 2020, 08:32:23 pm »
Into the subloom that runs behind the front cowling and under the headlight etc. But from all the questions, its sounds like your not that well equinted with electronics & electrical engineering. So in this instance I suggest just buying the spots and getting a mechanic or better a motorcycle alarm tech to fit the lights for you. Or if your close enough to Hertfordshire I will fit them for you.
b1k3rdude
« Reply #15 on: 30 August 2020, 08:37:51 pm »
A potential issue with this is thats lower down, than mine were. So its possible they will collect more road spray/crap.
kitcrazy
« Reply #16 on: 30 August 2020, 09:19:22 pm »
Wouldn't fancy riding around your way at night dazza :eek :lol
WayneUK
« Reply #17 on: 08 September 2020, 09:33:29 am »
:rolleyes
WayneUK
« Reply #18 on: 12 September 2020, 02:51:05 pm »
Hi on the left side front panel where the headlight loom connects to the plug whet number is the pin for the live headlight wire please?
CatalinU
« Reply #19 on: 12 September 2020, 09:20:48 pm »
What lights are you using. Any good cheap ones?
« Reply #20 on: 12 September 2020, 10:29:32 pm »
:lol  All those little lanes take on a whole new appearance at night mate. Must meet up soon.
Haven't got round to fitting them to the Fazer yet but have the MT10.
I've angled them so they light up round the corne when I'm cranked over.
Ended up buying 4 X 400W spot and flood lamps and they seem to do the job nicely.
