Date:
09-05-26
Time:
06:35 am
Home
Media
old - Fazer Owners Club - old
FZS600 Fazer
Breather?
« previous
next »
Print
Pages: [
Author
Topic: Breather? (Read 2002 times)
deeteefifty
DAS Born Again
Breather?
on:
26 August 2018, 07:42:48 pm »
Hello, I removed the carburettors to free off a seized tick over adjuster and on strip down noticed the item marked with a green arrow, should connect somewhere or does it vents to atmosphere?
Logged
Club Racer
Re: Breather?
Reply #1 on:
26 August 2018, 08:09:44 pm »
It vents to the atmosphere.
Logged
deeteefifty
DAS Born Again
Re: Breather?
Reply #2 on:
26 August 2018, 08:42:52 pm »
Ta very much bandit for your quick reply👍
Logged
Naughty Corner
GP Hero
Re: Breather?
Reply #3 on:
27 August 2018, 11:28:55 am »
As Bandit says, it doesn’t attach to anything else.
It looks twisted out of position in your photo though, it normally faces backwards: which might give that wiring it’s pressing against a bit more room.
Logged
deeteefifty
DAS Born Again
Re: Breather?
Reply #4 on:
27 August 2018, 11:43:03 am »
Ta fazerider. I've a bit re routing to do, the clutch cable has a sharp bend on its way from the frame top tube then behind the side cover, but maybe there's no choice with that one.
Logged
Naughty Corner
GP Hero
Re: Breather?
Reply #5 on:
27 August 2018, 11:04:57 pm »
If you think a previous owner may have messed things up there’s a diagram for cable routing in the manual (available in the downloads section).
Logged
deeteefifty
DAS Born Again
Re: Breather?
Reply #6 on:
28 August 2018, 06:50:33 am »
Thanks, found it and things aren't too far off. The tight bend in the clutch cable from frame top tube to casing looked suspicious but surprisingly this matched with the diagram🤔
Logged
Print
Pages: [
« previous
next »
FZS600 Fazer
Breather?
SMF 2.0.19
SMF © 2011
Simple Machines
Simple Audio Video Embedder
Crushing Theme by
Diego Andrés
XHTML
RSS
WAP2
