Date: 09-05-26  Time: 08:35 am
Author Topic: Breather?  (Read 2004 times)
deeteefifty
Breather?
« on: 26 August 2018, 07:42:48 pm »
Hello, I removed the carburettors to free off a seized tick over adjuster and on strip down noticed the item marked with a green arrow, should connect somewhere or does it vents to atmosphere?
bandit
Re: Breather?
« Reply #1 on: 26 August 2018, 08:09:44 pm »
It vents to the atmosphere..Smile
deeteefifty
Re: Breather?
« Reply #2 on: 26 August 2018, 08:42:52 pm »
Ta very much bandit for your quick reply👍
Re: Breather?
« Reply #3 on: 27 August 2018, 11:28:55 am »
As Bandit says, it doesn’t attach to anything else.
It looks twisted out of position in your photo though, it normally faces backwards: which might give that wiring it’s pressing against a bit more room.
deeteefifty
Re: Breather?
« Reply #4 on: 27 August 2018, 11:43:03 am »
Ta fazerider. I've a bit re routing to do, the clutch cable has a sharp bend on its way from the frame top tube then behind the side cover, but maybe there's no choice with that one.
Re: Breather?
« Reply #5 on: 27 August 2018, 11:04:57 pm »
If you think a previous owner may have messed things up there’s a diagram for cable routing in the manual (available in the downloads section).
deeteefifty
Re: Breather?
« Reply #6 on: 28 August 2018, 06:50:33 am »
Thanks, found it and things aren't too far off. The tight bend in the clutch cable from frame top tube to casing looked suspicious but surprisingly this matched with the diagram🤔
