Date: 08-05-26  Time: 09:06 am
Author Topic: Float bowl  (Read 3633 times)
reaper1064
Float bowl
« on: 27 April 2018, 08:45:59 am »
Hi guys want to remove the bowl off the right hand outer carb without stripping them all off. Any one doe this and have any tips. Cheers.
Starfazer
Re: Float bowl
« Reply #1 on: 27 April 2018, 08:52:27 am »
I think it should be possible with the right tools. Not easy, but possible.
First, drain the carbs. Then you'll need a Philips No.2 driver mounted on something like a 1/4" ratchet wrench to get in there for the two inner screws. The two outer screws should be removable with a normal screwdriver. One of those flexible mirrors would be handy too.
reaper1064
Re: Float bowl
« Reply #2 on: 27 April 2018, 08:59:33 am »
Cheers mate
daviee
  • Guest
Re: Float bowl
« Reply #3 on: 27 April 2018, 06:46:51 pm »
curious why would you only want to remove one ?
reaper1064
Re: Float bowl
« Reply #4 on: 27 April 2018, 07:02:03 pm »
The carb has I think has a small amount of crap in it, it fires on 3 at low revs and picks up on the main jet. Just want to pop it off to see the what's what. The original tank had bad corrosion in it, I've put a new onde on but suspect crap may be partially blockin a jet.
daviee
  • Guest
Re: Float bowl
« Reply #5 on: 27 April 2018, 07:10:29 pm »
you could prolly get it with a bit set with 75mm bits have you tried using the drain screw to see if it clears it
reaper1064
Re: Float bowl
« Reply #6 on: 27 April 2018, 09:40:09 pm »
Not yet mate but will give that a go first. Last owner seemed to have been fixated on the look of the bike and not so much on the service side.
Re: Float bowl
« Reply #7 on: 28 April 2018, 10:18:34 am »
Shove a whole bottle of STP Complete Fuel System Cleaner in a full tank of petrol, it's the only cleaner i've ever known to actually work!
reaper1064
Re: Float bowl
« Reply #8 on: 28 April 2018, 10:25:54 am »
cheers mate.
His Dudeness
Re: Float bowl
« Reply #9 on: 28 April 2018, 11:38:16 am »
Could be arcing through the spark plug caps causing that too. A set of NGK's and trim the ht leads could help
reaper1064
Re: Float bowl
« Reply #10 on: 28 April 2018, 11:42:02 am »
Had new plugs in the last couple of weeks, couldn't hurt trimming the leads back a bit though.
