Date: 21-03-26  Time: 07:29 am
Author Topic: Led light  (Read 1829 times)
chrischristopherson1313
Led light
« on: 26 April 2017, 09:49:35 pm »
Changed indicators to led and they doesn't work when headlight is on. Do I need to change H4 bulb to led as well. Normal bulbs indicators works fine. Check on both relays (led and oem)
slappy
Re: Led light
« Reply #1 on: 27 April 2017, 08:03:32 am »
I could be wrong here but don't you need to fit some sort of inline resistor to get led indicators to work correctly?
Re: Led light
« Reply #2 on: 27 April 2017, 08:06:36 am »
I put led relay so indicators works fine.
Only when I turn lights on they stop working.
slappy
Re: Led light
« Reply #3 on: 27 April 2017, 08:15:40 am »
I would check that all your earth points are good, clean them up and use contact cleaner on all connectors, check any wiring you might have disturbed when fitting the relay and indicators.
BBROWN1664
Re: Led light
« Reply #4 on: 27 April 2017, 09:21:08 am »
Sounds like a wiring issue.
Bretty
Re: Led light
« Reply #5 on: 27 April 2017, 10:28:52 am »
The wiring diagram in the Haynes manual is pretty handy when fault finding the lights and indicators.
