Date:
27-03-26
Time:
15:44 pm
Home
Media
old - Fazer Owners Club - old
FZS600 Fazer
help jacking off or is that up
« previous
next »
Print
Pages: [
Author
Topic: help jacking off or is that up (Read 1996 times)
BT
Naughty Corner
CBT Wobbler
on:
16 March 2012, 05:17:19 pm »
Help please
I need a touch more height so thinking jack up kit
can they be replaced as in one pair off new ones on or will suspension compress/extend ???really don't want to get into silly problems
I once removed crash bars to paint off a BMW GS only to find they would not go back on because the bolts where holding the engine up had to jack the engine up bit of a panick at the time
thanks in advance
Brian
Logged
Naughty Corner
GP Hero
Re: help jacking off or is that up
Reply #1 on:
16 March 2012, 07:17:06 pm »
So long as the bike's on the centrestand you shouldn't have a problem. Jam a wedge of wood under the back wheel to take its weight as you get the dogbone bolts out, then ease it down a bit to get the new ones to line up with the holes.
Logged
BT
Naughty Corner
CBT Wobbler
Reply #2 on:
17 March 2012, 05:41:12 pm »
thanks for that ...
does anyone sell them on the site ?
is 25mm the norm I have seen different lengths but read here it can affect the handling??
any ideas anyone
Brian
Logged
Naughty Corner
GP Hero
Reply #3 on:
17 March 2012, 11:35:54 pm »
Try Fazbaz on here, I know he used to fabricate them to order.
Alternatively this lot:
http://www.projection-components.co.uk/quad-length-jack-up-links-select-model-18-p.asp
do a clever version that offers a choice of lengths.
Yes, it will have an effect on handling because the forks will be at a slightly steeper angle. If you find it too twitchy (quite likely if you go for more than a 25mm increase) then increase the front fork preload or fit stiffer springs to compensate. Might be worth doing that anyway if you're on the heavy side.
Logged
Print
Pages: [
« previous
next »
FZS600 Fazer
SMF 2.0.19
SMF © 2011
Simple Machines
Simple Audio Video Embedder
Crushing Theme by
Diego Andrés
XHTML
RSS
WAP2
