Date: 09-02-26  Time: 09:14 am
Author Topic: help jacking off or is that up  (Read 1726 times)
BT
« on: 16 March 2012, 05:17:19 pm »
Help please
I need a touch more height so thinking jack up kit
can they be replaced as in one pair off new ones on or will suspension compress/extend ???really don't want to get into silly problems
I once removed crash bars to paint off a BMW GS only to find they would not go back on because the bolts where holding the engine up had to jack the engine up bit of a panick at the time
thanks in advance
Brian
Re: help jacking off or is that up
« Reply #1 on: 16 March 2012, 07:17:06 pm »
So long as the bike's on the centrestand you shouldn't have a problem. Jam a wedge of wood under the back wheel to take its weight as you get the dogbone bolts out, then ease it down a bit to get the new ones to line up with the holes.
BT
« Reply #2 on: 17 March 2012, 05:41:12 pm »
thanks for that ...
does anyone sell them on the site ?
is 25mm the norm I have seen different lengths but read here it can affect the handling??
any ideas anyone
Brian
« Reply #3 on: 17 March 2012, 11:35:54 pm »
Try Fazbaz on here, I know he used to fabricate them to order.
Alternatively this lot:
http://www.projection-components.co.uk/quad-length-jack-up-links-select-model-18-p.asp
do a clever version that offers a choice of lengths.
Yes, it will have an effect on handling because the forks will be at a slightly steeper angle. If you find it too twitchy (quite likely if you go for more than a 25mm increase) then increase the front fork preload or fit stiffer springs to compensate. Might be worth doing that anyway if you're on the heavy side.
