Date: 01-05-26  Time: 21:24 pm
Author Topic: Exup servo pulley - lubricate?  (Read 3257 times)
Jagman
« on: 20 October 2016, 10:57:25 pm »
Finally got rid of a persistent EXUP error reading after several adjustments of the cables... but noticed the servo pulley looks heavily rusted. Would spraying it with WD40 damage cable traction on the pulley?
cl1ve2004
Re: Exup servo pulley - lubricate?
« Reply #1 on: 21 October 2016, 12:50:01 pm »
doing mine at moment but if you search here and Pats site plenty of info..cant do any damage soaking with wd40
PieEater
« Reply #2 on: 21 October 2016, 03:01:52 pm »
WD40 was not designed as a lubricant so there are better alternatives for this purpose such as 3 in 1 with PTFE to name just one.
Andy W
« Reply #3 on: 21 October 2016, 06:30:14 pm »
GT-85 is also a good aerosol PTFE spray.
Cheap enough & readily available.  :)
chriswarren
« Reply #4 on: 21 October 2016, 08:39:48 pm »
Thx - I'll use a better lubricant, but I was more worried whether lubricating the pulley and the cable around it will make the pulley slip against the cable?... or doesn't it work this way?
Tmation
« Reply #5 on: 22 October 2016, 06:08:24 am »
The cables are fixed at both ends so can't slip like drive belt on a car. One cable pulls the valve open the other pulls it closed
Rob
« Reply #6 on: 22 October 2016, 09:11:03 am »
I put copper grease over the lot due to the heat burning off oils and as stated the wires clip into the pulley and work from fixed points on the pulley,
