Date: 18-01-26  Time: 06:08 am
Author Topic: Starting problems on 2008 avensis  (Read 1310 times)
tex
« on: 12 September 2016, 11:56:38 am »
After a bit of advice , Toyota avenue 08 d4d diesel . Drives fine no warning lights coming on cranking OK but won't start happend a week ago so bumped started it and was OK until today, sometimes it takes a bit to start but no go this morning. Before I take it to the garage anyone got any ideas. Thanks
BBROWN1664
Re: Starting problems on 2008 avensis
« Reply #1 on: 12 September 2016, 12:23:10 pm »
Try some ezstart in the air filter.
Could be a battery problem causing the ECU to not pump fuel whist cranking due to voltage drop.
Frosties
« Reply #2 on: 12 September 2016, 11:05:22 pm »
Starter motor on the way out leaving not enough current for the glow plugs.
Ignition barrel issue.
Any exhaust emissions when trying to start?
Immobiliser issue?
crickleymal
« Reply #3 on: 13 September 2016, 09:08:41 am »
Glow plugs. Battery. Could be immobiliser although because it cranks over I'm not sure. Do you have a spare key? If so try that and that will eliminate the immobiliser.
tex
« Reply #4 on: 13 September 2016, 11:22:30 am »
Thanks for all your help , I'll try all suggestions
 I got it towed to a hill near by tried to bump start it, no joy, there no smell of diesel so maybe fuel pump .
