Date: 02-05-26  Time: 19:30 pm
Author Topic: Clutch problems.....  (Read 2517 times)
Trip
« on: 03 April 2016, 10:25:05 pm »
I'm sat in an AA van as I write this, I passed my test last August and went out and bought an 03 fazer which I instantly fell in love with.
Today however she's breaking my heart.
Riding along my and the clutch lever wouldn't work, I could move it but it was loose and not doing what a clutch lever should.... Thinking the cable must have snapped I killed the engine and pulled over, as I did so, I saw a big pool of oil appear below the gear lever.
Any thoughts as to what  this could be?
Any help or advice would be appreciated!
Deefer666
Re: Clutch problems.....
« Reply #1 on: 03 April 2016, 11:32:27 pm »
Sounds like a problem with the clutch push rod where it goes into the engine under the front sprocket housing... Are you sure the chain hasnt snapped?
Trip
« Reply #2 on: 03 April 2016, 11:48:13 pm »
Thanks Deefer,
No I'm not 100% certain, but would this cause an oil leak? I'm not talking a couple of drops, this was a puddle (all over by back wheel too ! 😕)
Bretty
« Reply #3 on: 04 April 2016, 08:50:52 am »
I've had something similar happen to me on a long ride back from Hamburg.
My scottoiler ran dry, chain stretched, jumped a tooth on the front sprocket and hit the push rod, snapping it and dislodging the seal. I don't remember a lot of oil coming out though? But this would be my guess.
Deefer666
« Reply #4 on: 04 April 2016, 09:00:50 am »
Tha'ts what I'm thinking... take your sprocket housing off and in front of the sprocket you should see a rod coming out of the engine, if there is just a hole that is leaking oil then your chain has either snapped or jumped and knocked the top off of the clutch push rod. I have also seen this happen when the front sprocket retaining nut has failed.
Trip
« Reply #5 on: 10 April 2016, 05:34:00 pm »
Thanks for the input guys, you were quite right, it was a sheared push rod.  Chain was intact though.
