Date:
21-04-26
Time:
09:18 am
Home
Media
old - Fazer Owners Club - old
Fazer 1000/FZ1 corner
Throttle grip housing repair?
« previous
next »
Print
Pages: [
Author
Topic: Throttle grip housing repair? (Read 1812 times)
Marc125030
DAS Born Again
on:
09 February 2016, 08:15:19 pm »
My throttle grip lug which stops the switch rotating on the bar has snapped off, is the a diy repair or will i need to source another switch assembly?
Logged
b1k3rdude
Administrator
GP Hero
Re: Throttle grip housing repair?
Reply #1 on:
09 February 2016, 08:53:52 pm »
I would say your better off just replacing the housing, they are cheap enough. And as it happens I have one of a 2005 model (dosent have the headlight switch) if your interested.
Logged
markie_wales
Naughty Corner
Weekend Warrior
Reply #2 on:
09 February 2016, 09:17:57 pm »
Not sure a repair will hold, get a replacement or wrap some (as best you can) colour matched gaffer tape around the bar, then refit "snug". It's usually enough to stop them spinning.
Cheers
Markie
Logged
Motopsycho87
DAS Born Again
Reply #3 on:
10 February 2016, 10:28:22 am »
I cut mine off and just used electrical tape around the bar to clamp it tighter so I could go renthal, works fine!
Logged
Marc125030
DAS Born Again
Reply #4 on:
11 February 2016, 06:24:18 pm »
I managed to repair the old plastic housing with a cut down screw
I drilled a suitable hole in the lug where it had snapped off and used a screw to create a thread then cut it to a suitable length and voila it holds perfectly
Logged
Print
Pages: [
« previous
next »
SMF 2.0.19
SMF © 2011
Simple Machines
Simple Audio Video Embedder
Crushing Theme by
Diego Andrés
XHTML
RSS
WAP2
