Date: 21-04-26  Time: 09:19 am
Author Topic: Throttle grip housing repair?  (Read 1815 times)
Marc125030
« on: 09 February 2016, 08:15:19 pm »
My throttle grip lug which stops the switch rotating on the bar has snapped off, is the a diy repair or will i need to source another switch assembly?
Re: Throttle grip housing repair?
« Reply #1 on: 09 February 2016, 08:53:52 pm »
I would say your better off just replacing the housing, they are cheap enough. And as it happens I have one of a 2005 model (dosent have the headlight switch) if your interested.
markie_wales
« Reply #2 on: 09 February 2016, 09:17:57 pm »
Not sure a repair will hold, get a replacement or wrap some (as best you can) colour matched gaffer tape around the bar, then refit "snug". It's usually enough to stop them spinning.
Markie
Motopsycho87
« Reply #3 on: 10 February 2016, 10:28:22 am »
I cut mine off and just used electrical tape around the bar to clamp it tighter so I could go renthal, works fine!
Marc125030
« Reply #4 on: 11 February 2016, 06:24:18 pm »
I managed to repair the old plastic housing with a cut down screw
I drilled a suitable hole in the lug where it had snapped off and used a screw to create a thread then cut it to a suitable length and voila it holds perfectly
