Date: 08-04-26  Time: 17:18 pm
Author Topic: Sprocket Cover  (Read 2707 times)
Fuzzy
Sprocket Cover
« on: 27 February 2012, 04:14:27 pm »
After hearing all the scarey stories about Fazers with failing sprocket nuts I thought I'd go check mine just in case. I would have just gone ahead with it as I have done with other bikes, but I had a Haynes manual at hand so thought I'd have a look at that first.
Anyway, it said that there is a gasket that needs replacing if you take the sprocket cover off - is this correct? On previous bikes, it's just been a matter of removing the cover, usually plastic, and that's it. All I want to do is check the sprocket nut and shaft - do I need to buy a gasket beforehand or am I getting confused?
Thanks!
HarryHornby
Re: Sprocket Cover
« Reply #1 on: 27 February 2012, 04:51:08 pm »
there is a gasket.  When I removed mine to check it disintegrated in my hands.  I bought a new one from Yamaha, think it cost about £6.
Fuzzy
Re: Sprocket Cover
« Reply #2 on: 27 February 2012, 05:01:45 pm »
Great, thanks for clearing that up, I'll order one now. Out of interest, do you know why there is a gasket there? Is this common on some bikes?
Fazer Jake
Re: Sprocket Cover
« Reply #3 on: 27 February 2012, 05:29:38 pm »
I removed my gasket, couldnt see the need in it  :\
Fuzzy
Re: Sprocket Cover
« Reply #4 on: 27 February 2012, 05:30:58 pm »
Yeah, that's what I thought - I can't figure out why it would be necessary there...
limax2
Re: Sprocket Cover
« Reply #5 on: 27 February 2012, 07:13:34 pm »
In some applications a gasket is fitted to stop fretting on the mating faces, but I don't see this as one of those situations. Mine has always stayed intact so is still there, but I tend to agree with Jake that it is not necessary.
If you do away with it I would check the clutch adjustment at that case end because you will loose a slight amount of clearance.
Mosser
Re: Sprocket Cover
« Reply #6 on: 27 February 2012, 08:09:44 pm »
The only use i can see for  gasket on that cover is to stop the grease thats flung off the chain leeching through the join where the gasket is and making a mess on the outside of the bike.
My gasket broke into 3 pieces when i took mine off to fit the new nut and washer kit and i just used some hylomar gasket jointing compound, but you could use anything thats to hand, even a bit of silicone bath sealant would do the same job
Fuzzy
Re: Sprocket Cover
« Reply #7 on: 27 February 2012, 09:51:08 pm »
Thanks, glad I asked as I was worried it had a more important function. Perhaps it's not worth buying one after all!
marksfazer
Re: Sprocket Cover
« Reply #8 on: 28 February 2012, 08:23:48 am »
I have never replaced the gasket,  I like to take the cover every now and then to check my sprocket nut. I don't see the point of the gasket.
