Date: 10-05-26  Time: 02:40 am
Author Topic: nut debate  (Read 4202 times)
devilsyam
nut debate
« on: 01 September 2015, 01:06:31 pm »
Well been bit of discussion between mates on which side the axle nut should be all my gen 1's have been on the right side (when sat on bike)
And the same on my gen 2
Steves is on the left as is hedgetrimer 3
Is there a correct side can't see makes f all difference
Debate
Dead Eye
Re: nut debate
« Reply #2 on: 01 September 2015, 02:07:12 pm »
Mine's on the left as in the above diagram - same with both my Boxeyes as well :)
lew600fazer
Re: nut debate
« Reply #3 on: 01 September 2015, 02:25:58 pm »
My Gen 2 is on the right hand side (brake side) I would imagine as it is a right hand thread it would follow that direction of rotation wheel may have something to do with it ??
devilsyam
Re: nut debate
« Reply #4 on: 01 September 2015, 02:31:37 pm »
That was my theory
HarryHornby
Re: nut debate
« Reply #5 on: 01 September 2015, 04:41:27 pm »
my first boxeye and my current one have the nut on the left.
PS, don't suppose you have 2 washers for a Fzs600 rear axle do you?
Skippernick
Re: nut debate
« Reply #6 on: 01 September 2015, 05:00:39 pm »
Cashews are the best nuts!
Re: nut debate
« Reply #7 on: 01 September 2015, 05:09:16 pm »
Mine's on the right side which would be the left,  can't see that it makes any difference except the exhaust can restrict movement of a long torque wrench and less likely to burn yourself on it.
Re: nut debate
« Reply #8 on: 01 September 2015, 06:26:48 pm »
The axle would be more inclined to follow the wheel rotation which would cause it to rotate anti clockwise, this which would effectively loosen the nut as it has no reason to move ?????  :eek
All the Gen 1 and the 600s are on the left, all gen 2s are on the right, the Fz6 is on the left and Fz8 is on the right, focs up all theories
slimwilly
Re: nut debate
« Reply #9 on: 01 September 2015, 09:00:52 pm »
What  an odd question,,but then when you think about it, a good question,,so does it make a difference, yes if the nut is on the clutch lever side then if an wheel  could possibly seize and grab a wheel bolt then I would unwind it, but then if it was the other way then a serious lock up would occur..
Well I think not,,just put the correct washers,spacers,anti twist plates etc on in the right place and bobs your uncle
joebloggs
Re: nut debate
« Reply #10 on: 01 September 2015, 09:09:19 pm »
Its the nut on the steering thats the issue
noggythenog
Re: nut debate
« Reply #11 on: 01 September 2015, 10:18:49 pm »
Harry are you still on about these things.....have you got any to compare against as I might have them in the shed if they are specific....if they are just standard ish looking washers then I probably used them on something else but bespoke and they might be lurking around......or I might have given them to fizzy when he got my swingarm....anyway get a pic up. :photo
esetest
Re: nut debate
« Reply #12 on: 02 September 2015, 04:25:53 pm »
Mines on the left , assumed they were all like that .
