Date: 08-05-26  Time: 01:55 am
Author Topic: 6th gear?  (Read 12573 times)
JFFaz
6th gear?
« on: 22 February 2015, 10:06:45 am »
Hi,
So I've been a reader for a while but never managed to join to now. I have a FZS 600 (2000 model) a while now and am concerned to be honest. Mostly I ride around London so 4th is as high as I've needed to go, however having taken it for a few blasts down the motorways etc, I've noticed it won't find 6th. It's like the gear just isn't there :(
I'm not really sure what I can do to look into this. I mean, for you other owners, can you find 6th while sitting with it turned off? Are there any tricks to getting it? I mean, other than the usual clunky 2nd gear, the rest are fine!
Any help at all would be great. A very confused fazer owner
*also to add, I've found this forum to be really helpful for other small issues so thanks for your inadvertent help already :)
Re: 6th gear?
« Reply #1 on: 22 February 2015, 11:27:32 am »
Not entirely sure what to say to that?
Paulfzs
Re: 6th gear?
« Reply #2 on: 22 February 2015, 01:03:11 pm »
gear selector fork bent?
worn dogs?
JFFaz
Re: 6th gear?
« Reply #3 on: 22 February 2015, 01:29:33 pm »
Gear selector is fine, but am going to have a look and see if I can adjust it at all.
Looking at other forums where similar things have happened to other bikes, it may be clutch related. No two idea myself though. Just hoping it's not going to be an expensive trip to the garage :(
stevie-g1968
Re: 6th gear?
« Reply #4 on: 22 February 2015, 01:55:38 pm »
you are counting right arnt you, as you change up ;)....I keep looking for 7th gear... :rolleyes :lol
Millietant
Re: 6th gear?
« Reply #5 on: 22 February 2015, 03:35:28 pm »
I almost never us the clutch on upshifts, except for the 1st to 2nd change; and 6th snacks in beautifully without the clutch - so I'm thinking that the "clutch problem" is a red herring.
As for other ways of changing gear, try shifting from 5th to 6th with just a quick little roll off/roll on of the throttle as you snick the gear lever up.
Re: 6th gear?
« Reply #6 on: 22 February 2015, 03:57:53 pm »
If he can't find 6th whilst using the clutch i doubt it'll suddenly appear by not using it!
Fazafou
Re: 6th gear?
« Reply #7 on: 22 February 2015, 04:58:39 pm »
Lol, I hate to say it but was thinking the same.
See so many new riders on forums with schoolboy errors (we've all been there), and wondered if it was due to counting 1 on the first upshift to second :)
Paulfzs
Re: 6th gear?
« Reply #8 on: 22 February 2015, 05:09:20 pm »
how do you know?
did you take it out and look?
JFFaz
Re: 6th gear?
« Reply #9 on: 22 February 2015, 05:22:12 pm »
Sadly no, I'm counting 1 down then 2, 3,4 &5 up. Unless neutral is a gear I'm only getting 5. I thought I'd miscounted the first few times, hence me just carrying on. Which is why I feel even more stupid now.
Think there's nothing for it but to ask a garage.
Just hoped maybe someone else has experienced the same thing and knew what to suggest. Daft thing is, I could live with 5.. If I wasn't supposed to have 6!
*sorry, by fine I meant the lever isn't bent, as the first point. In terms of looking at that, is it an easy job?
Paulfzs
Re: 6th gear?
« Reply #10 on: 22 February 2015, 06:09:55 pm »
selector forks
what happens when you put it in 6th?
does it just go nowhere?
can you put it in 6th gear when stationary then rev it and not move... if so 6th is probably stripped
JFFaz
Re: 6th gear?
« Reply #11 on: 22 February 2015, 07:56:48 pm »
I can't get it into 6th either stationary or moving. The level moves up a bit but then stops as though there's nowhere to go. There's not even the slightest hint that there is something for it to move in to. I'm going to have a look at adjusting the selector myself, but that's about all I know how to do, so if that doesn't work I think I'll have to have someone look at it.
Very odd... Assuming I find out what it is I'll update it here.
Fazafou
Re: 6th gear?
« Reply #12 on: 22 February 2015, 08:51:18 pm »
Could be the rare 5 gear version, they only made a few and worth huge sums of cash.
Paulfzs
Re: 6th gear?
« Reply #13 on: 22 February 2015, 09:05:46 pm »
gear is 1 down 5 up just incase :D
sounds like a bent fork
Re: 6th gear?
« Reply #14 on: 22 February 2015, 10:29:36 pm »
 :rollin :rollin :rollin
JFFaz
Re: 6th gear?
« Reply #15 on: 24 February 2015, 11:38:04 am »
Well, last night I played around with the height adjuster of the Gear Selector. After much messing I actually ended up disconnecting it and reconnecting it. Didn't seem in a vastly different location, however, much to my surprise and excitement this morning, I now have a 6th gear!
All I can assume is that prior to me purchasing it the lever had been moved to such an extent that there wasn't the movement available to push the actual gear selector into 6th. Either way, needless to say, I'm both ecstatic at having all the gears I was expected and also feeling like a complete tool for not doing this before posting on the forum.
Hopefully, should anyone else be unfortunate enough to have a similar problem, they'll see this and save themselves the embarrassment.
Thanks for all the advice people and if nothing else I hope I provided some entertainment :)
I'm now off to ride around in 6th at completely inappropriate times, just because I can!
Re: 6th gear?
« Reply #16 on: 24 February 2015, 01:17:09 pm »
Hoorah, he found his gear.  :lol
Re: 6th gear?
« Reply #17 on: 24 February 2015, 06:34:31 pm »
Well done JFFaz.......if you look at the gear selector shaft you'll see a dot on the end , this should be inline with the gap where the bolt goes through on the lever...glad you sorted it   :)
noggythenog
Re: 6th gear?
« Reply #18 on: 24 February 2015, 06:39:16 pm »
Nice handy hint there Red, ive focced about with mine quite a bit now, would the same dot apply on the gen 2 dya reckon???
Re: 6th gear?
« Reply #19 on: 24 February 2015, 06:48:30 pm »
The punch mark dot on the gear shaft should line up with slot on the toothed spline section of the gear change. It may not line up exactly but should be close enough, rotate it to the correct position before finally tightening it.
Same applies to all fazers
Re: 6th gear?
« Reply #20 on: 24 February 2015, 06:55:00 pm »
Unfazed mate....are you turning into noggy ?    :rollin :rollin :rollin
Re: 6th gear?
« Reply #21 on: 24 February 2015, 06:57:44 pm »
hi mr nog....yeh iam pretty sure the slow fazers are the same   ;)
rhinoeli
Re: 6th gear?
« Reply #22 on: 24 February 2015, 07:15:22 pm »
Adjust it a bit more and you may find the misterious 7th...
Re: 6th gear?
« Reply #23 on: 24 February 2015, 07:21:33 pm »
When I took mine off to polish I put my own mark on with a pen. I did see that it sort of lined up with the gap but did not know that was the official set up. I thought that you could position it where you was comfy and liked it within reason. Obliviously not then unless you don't want 6th.
noggythenog
Re: 6th gear?
« Reply #24 on: 24 February 2015, 07:38:35 pm »
Im the same as you, i thought i could just adjust it however.
Back to the drawing board for me.
Red....cheers......but i think you'll find with my average of 26.2mph im considerably quicker than you :lol
