Date: 11-05-26  Time: 12:05 pm
Author Topic: R6 shock Mod fazer 1000  (Read 316387 times)
Kenbob
Re: R6 shock Mod fazer 1000
« Reply #675 on: 24 February 2017, 07:59:27 pm »
Yep, I'm very pleased with the yellow one, looks brand new.
devilsyam
« Reply #676 on: 25 February 2017, 07:00:00 pm »
2 x red and one silver now in stock ready to go
ProdigalSon
« Reply #677 on: 27 February 2017, 11:39:58 am »
devilsyam
« Reply #678 on: 27 February 2017, 08:09:29 pm »
yep the bmw shock is a good mod also not quite out the box but still a good option
the stock shock isnt about failure more over its inability to perform correctly - there are other on here who can give you the low down on the bmw conversion and i thing someone was doing the bushes all i ask is you relocate to your own thread as id like to keep this r6 based
the above silver is heading to Ireland so i have two reds in stock
ProdigalSon
« Reply #679 on: 27 February 2017, 08:20:49 pm »
No idea how to relocate so all I've been able to do is remove the text, sorry if my post was inappropriate, cheers. :)
devilsyam
« Reply #680 on: 27 February 2017, 08:25:55 pm »
no was not inappropriate at all and i was happy for it to remain  just the information you require wound not be found here
better to start a new thread relating to the question
"yep the bmw shock is a good mod also not quite out the box but still a good option
the stock shock isnt about failure more over its inability to perform correctly - there are other on here who can give you the low down on the bmw conversion and i thing someone was doing the bushes all i ask is you relocate to your own thread as id like to keep this r6 based"
devilsyam
« Reply #681 on: 02 March 2017, 08:46:45 pm »
two reds in stock ready to go
devilsyam
« Reply #682 on: 06 March 2017, 09:19:15 pm »
bump spring is coming
devilsyam
« Reply #683 on: 09 March 2017, 05:55:21 pm »
spring is coming time to get ya bike out of mothballs and pimp that rear end
2 x red in stock
devilsyam
« Reply #684 on: 19 March 2017, 06:54:54 pm »
bump
devilsyam
« Reply #685 on: 27 March 2017, 08:17:42 pm »
Bumped
Hedgetrimmer
« Reply #686 on: 02 April 2017, 01:59:11 pm »
What's a typical sort of mileage you can expect to get out of one of these things (average sort of weight rider)? Mine's on about 27k now, and just starting to get a suspicion it's not at its best.
devilsyam
« Reply #687 on: 02 April 2017, 06:59:20 pm »
well thats 3 times the time a stock will last lol ive had them go to 50k nick but they will eventually need overhauling
Hedgetrimmer
« Reply #688 on: 02 April 2017, 07:28:48 pm »
Not complaining Luke, I wouldn't expect one to last forever, and I agree it has lasted in effective condition much longer than the standard crappy item would. It's just I've noticed the rear end isn't handling quick direction changes so well lately - feels like it needs a moment to settle. Or at least, I think so. I need to check it out a bit further yet, it might be just me. I was chasing (trying to) a Ducati 1299 on a fast winding A road the other day, so it may be I was just pushing harder than usual  :lol
But I was curious anyway - if it made it to 50k, I'd be very impressed.
devilsyam
« Reply #689 on: 13 April 2017, 07:45:49 pm »
bump
devilsyam
« Reply #690 on: 08 May 2017, 07:06:24 pm »
black in stock friday
devilsyam
« Reply #691 on: 12 May 2017, 10:22:39 pm »
Black sold red in stock as of Thursday
Thai
« Reply #692 on: 24 May 2017, 01:41:52 pm »
SORRY! Been out having so much fun on completely revitalised bike...forgot to say thanks!
Thanks VERY much indeed, bloody wonderful it is!!
devilsyam
« Reply #693 on: 26 May 2017, 07:25:19 am »
Great thxs for the feedback
Wee Rocky
« Reply #694 on: 31 May 2017, 02:14:56 pm »
Recieved my r6 shock from Devilsyam on Monday and fitted this morning. Huge difference especially in corners and very easy to do with the easy instructions. Thanks again Devilsyam and roll on the 7th of July when I get the full Monty done 😊ps I wouldn't have even known abouts these mods if it wasn't for you guys on this forum so thanks everyone!!
Covertlaugh
« Reply #695 on: 08 June 2017, 08:37:11 am »
Hi Devilsyam,
I have the r6 shock mod but have also just had ktec springs matched to my weight and 10w oil as recommended by ktec fitted. Forks are 10mm through yolks. I am 14 stone in kit. The bike is running on Dunlop Roadsmart 3's tyre pressures front 35 and rear 39. Since fitting the forks the bike has developed a high speed weave. This is during hard acceleration above 9k and towards the silly end of the speedo! Below that in general use or short shifting its fine.Any suggestions on the fork and rear suspension set up please? Sag seems correct. All usual suspect bearings have been checked and fine. Cheers
devilsyam
« Reply #696 on: 08 June 2017, 07:56:56 pm »
as this has happened after fork fit id be inclined to check front setting look for for sticksion make sure both legs have same setting
go back to factory settings as yo need a base point to work from
sticksion is when the fork are clamped either resting on the deck or if yokes tightened oddly
the way to remove it is lift front end remove wheel undo clamps so legs are relaxed
nip uo lower yoke first just enough to hold the leg
now tighten top yoke bit at a time left then right till both are torqued
now undo the lower yoke till bolts are loose this allows any tension out again clamp either side bit by bit till torqued
assuming all bearings are good and your happy go try it
also ive come across alot of fazers in my time were the front wheel is over tightened so check torque on this to
let me know how you get on
Covertlaugh
« Reply #697 on: 08 June 2017, 09:41:36 pm »
Great stuff. Will give it a try tomorrow. Thank you
Covertlaugh
« Reply #698 on: 09 June 2017, 04:22:00 pm »
So today I put the front forks back to recommended settings as per the fazer manual despite the ktec springs and thicker oil. I also put forks back to flush with yolks. I did as you suggested with the loosening of bolts, bouncing front and tightening. It made no difference. Hard acceleration around 110mph (closed road!) speed weave. Forks thru 10mm...standard settings...same. Forks thru 13mm! Same! Rear preload up to one off max. Same! Front rebound dialled back to absolute minimum and all as before...the bike is on its nose. Same though maybe not quite as violent. Really stumped! I am thinking of taking the forks back to the mechanic who fitted the springs and oil...summats up!
ram
« Reply #699 on: 09 June 2017, 05:11:24 pm »
have you got a steering damper? as these have been known to cause problems
