Date: 10-05-26  Time: 17:34 pm
Author Topic: carb balance  (Read 8295 times)
spyder
carb balance
« on: 27 August 2014, 09:40:03 pm »
Anyone know what size adapters I need for carb balancing? 5mm? And any ideas for accessing that no 3 mixture screw? V interesting problem...
Re: carb balance
« Reply #1 on: 27 August 2014, 10:14:14 pm »
Is that the one that needs the long #2 screwdriver?
Do a search above, it's been covered in several posts on here before in detail.
bandit
Re: carb balance
« Reply #2 on: 27 August 2014, 10:22:56 pm »
   There you go. :)
mickvp
  • Global Moderator
Re: carb balance
« Reply #3 on: 28 August 2014, 06:58:32 am »
It just needs to be a long star screwdriver, with a thin shank (you can grind the shank down a bit if need be). For clearance.
Re: carb balance
« Reply #4 on: 28 August 2014, 11:55:40 am »
robin78842
Re: carb balance
« Reply #5 on: 28 August 2014, 12:37:00 pm »
Try a pair of long nose pliers and turn an eighth at a time.
tweetytek
Re: carb balance
« Reply #6 on: 28 August 2014, 12:48:17 pm »
Mixture screw? ... When balancing carbs? Possibly you mean the throttle linkage screws? I bought a driver from eBay great tool and just for the job http://www.ebay.co.uk/itm/111383642364?_trksid=p2059210.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Gets into the screw's easy
Punkstig
Re: carb balance
« Reply #7 on: 28 August 2014, 02:26:18 pm »
Aldi were selling a set of long thin screwdrivers the other week- local store may have some left
tweetytek
Re: carb balance
« Reply #8 on: 28 August 2014, 03:43:46 pm »
what did they taste like
spyder
Re: carb balance
« Reply #9 on: 28 August 2014, 06:16:17 pm »
No. I did mean the mixture screw. I removed the carbs when the engine was running pretty badly, having been balanced by 2 bike shop.Removing the carbs  I found one mixture screw had completely fallen out! I replaced it, and set mixture screws to 2.25 turns out (they had been all over the place.) Instant improvement, almost perfect. Going to 2.5 turns on 3 screws made things deteriorate so now I want to reduce to 2 turns and that no 3 screw is v hard for my fat fingers to get at. I know Yam make a special tool but I wondered if anyone had any tips for getting round that.
Re: carb balance
« Reply #10 on: 28 August 2014, 06:48:33 pm »
Tough one this...ive been looking for a sidewinder tool for a while now.its a racthet screwdriver with the usual changeable heads but with a right angle head and a small t bar on the end of the handle to operate the rachet....small and lightweight idea for this job.....otherwise, as you know its carbs off a small tweek and back on again, reapeted untill its "just right"....very time consuming....was'nt aware of the yam tool, do you know how much they are ?
Exupnut
Re: carb balance
« Reply #11 on: 28 August 2014, 07:22:45 pm »
Hehehe....Genius....dont think i forgot Mr Red...
spyder
Re: carb balance
« Reply #12 on: 28 August 2014, 08:44:58 pm »
I think this is it :      http://www.manualslib.com/manual/656701/Yamaha-Yzf-R6-99.html?page=17    I know it says YZF but I believe it would be ok for other bikes too.   Part no 90890-03158 but it doesn't seem readily available, and it's expensive. I refuse to remove the carbs just to tweak 1 carb, I WILL cobble something together :eek
spyder
Re: carb balance
« Reply #13 on: 28 August 2014, 08:54:28 pm »
Re: carb balance
« Reply #14 on: 28 August 2014, 09:52:09 pm »
Cant see that yam tool working.....I do like the sealey tool though.little bit expensive but a great time saver....might just look into this a bit more... :thumbup
Re: carb balance
« Reply #15 on: 28 August 2014, 09:55:51 pm »
mr red not forgotten, i've got a good memory mr black..... :lol
midden
Re: carb balance
« Reply #16 on: 29 August 2014, 12:20:52 am »
Is there a specific reason why the tps has to be unplugged and reset when balancing carbs?
Re: carb balance
« Reply #17 on: 29 August 2014, 05:41:05 am »
Damn, i was flicking through an old post yesterday and somebody wrote "You need to check the TPS after a carb balance because....." and i didn't read any further!  :rolleyes
midden
Re: carb balance
« Reply #18 on: 29 August 2014, 08:57:55 am »
so it has been explained before then. I did quickly scan the threads but didn't find an answer
Re: carb balance
« Reply #19 on: 29 August 2014, 11:21:54 am »
".....When you balance the carbs you change the position of the flaps on carbs 1, 2 and 3 relative to 4 where the TPS is. So you can (depending on how much you adjust them) put the TPS out of adjustment. Hence the check....."
