Date: 10-05-26  Time: 10:00 am
Author Topic: Fork oil 15w  (Read 3492 times)
tweetytek
Fork oil 15w
« on: 27 August 2014, 04:55:25 pm »
Going to replace stock 5w with 15w in the forks... Found some guides
DIY How to Replace Motorcycle Fork Oil Yamaha FZ6…:
How to change fork seals in traditional (right wa…:
And a link  on focuk that doesn't have the pics
Looking for some ideas tips but the above either miss out tips n hints, or the methods differ slightly,  or the images are missing...
Tips like how to get the rod out, get right oil level, order of bolt removal....
Does anyone have a link to a 101 for a fzs
Rather bemusing... For fork oil change, The Haynes manual says refer to chapter 1, chapter 1 says refer to chapter 6. But I guess you just miss out some (unknown) steps although I have had bad experiences with Haynes as the odd thing gets left out or wrong order
Oh,and what will 15w give me over 5w. My commute is through B roads and country lanes, if that matters. My firms don't bottom out and roads are very uneven and potty and scarred tarmac, so, should I sick with 5w. The fork oil hasn't been changed in 17k according to previous owner
Cheers
Re: Fork oil 15w
« Reply #1 on: 27 August 2014, 06:25:42 pm »
Normal oil is 10w.
15w will firm up the front end and in my opinion makes it feel much more stable and predictable.
You will feel the bumps a little bit more though, so if you reckon you'll be using dodgy roads then maybe standard the 10w oil will be better for you.
To be honest i reckons it's a personal thing, although if you are a lightweight rider then stick with the 10w, but if you are a heavier rider or take luggage or passengers on a regular basis then i'd suggest 15w is the way to go.
NOTE: Your bike is an FZS600, not an FZ6.
tweetytek
Re: Fork oil 15w
« Reply #2 on: 27 August 2014, 06:27:27 pm »
Normal oil is 10w.
OK mate. I'll stick with 10. I thank you  ;)
Re: Fork oil 15w
« Reply #3 on: 27 August 2014, 06:29:23 pm »
Normal oil is 10w.
Check my added note above.
tweetytek
Re: Fork oil 15w
« Reply #4 on: 27 August 2014, 06:31:47 pm »
I know. But I could not find a vid on fzs.
I have changed fork oil before on other bikes but not this one and wondered if there are any gotchas. I guess not but just checking
Re: Fork oil 15w
« Reply #5 on: 27 August 2014, 08:10:45 pm »
I was referring more to the fact that the FZ6 uses different oil, so don't presume things are the same between bikes.  ;)
tweetytek
Re: Fork oil 15w
« Reply #6 on: 27 August 2014, 08:26:48 pm »
absolutely you are right.  Cheers. Mine is a fzs , so we're on the same page mate. Thanks
