Date: 08-05-26  Time: 06:45 am
Author Topic: Bouncing Fuel Guage  (Read 2256 times)
HJFazer
Bouncing Fuel Guage
« on: 04 August 2014, 05:48:53 pm »
Hi,
So as the subject suggests, ever so often, usually after about 2 hours of motorway riding, my fuel guage decides to just bounce up and down as it wishes for a while. I figured maybe it was to do with the temperature of the bike affecting a connection somewhere as it only really happens after its been in use solidly for a couple of hours.
After I've stopped it seems to go back to normal with no issues. I just wondered if anyone else had encountered this before at all or if anyone had any ideas? I'm not massively concerned, I know what I get to a tank so I can judge it, but I'd still like to fix it if possible
Cheers
HJR
keratos
  • Guest
Re: Bouncing Fuel Guage
« Reply #1 on: 04 August 2014, 07:43:13 pm »
Only sure way is to test the sender in situ and also off tank....
Can you remove/able to remove the sender and we can run some electrical diagnostics?
Sanchezz
« Reply #2 on: 04 August 2014, 08:47:59 pm »
I had the same issue. Checked the wires and cleared connection that is on the frame under the tank (lift the tank and you will see it), a bit of corrosion there and loose connection itself. Works ok from then! Hope that helps!
richfzs
« Reply #3 on: 04 August 2014, 09:06:09 pm »
Obviously, you're filling up with kangaroo petrol....
coat on, gone...
keratos
  • Guest
« Reply #4 on: 04 August 2014, 09:06:29 pm »
Correct. Id jumping the gun there. I usually propose foccers run wiring checks first, always. So good suggestion. Sorry
Paulfzs
« Reply #5 on: 04 August 2014, 10:52:36 pm »
I have this issue too, my old bike, suzuki gsx 600f did the same...
I can have empty tank, put £10 in it will show full, ride it for 10 miles ill have half a tank then a full tank! then itll go down slowly and then fuel light on and off for miles then itll finaly go from 1/4 to FILL UP OMFG!!
or i put £25 fuel in and well it does the same just a bit slower.
HJFazer
« Reply #6 on: 06 August 2014, 11:55:57 am »
Cheers guys, will take a look at the weekend and see if I can figure it out...
richfzs - Absolutely terrible joke there!!! I like it  :)
